Running the 18 May test build on Windws 10 Pro, both the audio input and output lists are doubled up. Is this a known ‘feature’ or a quirk of my machine?!
Hi Martin.
This is a consequence of the Qt library that handles audio for wfview. It supports two types of audio drivers on Windows and displays them both. I can probably filter this more so only the ‘preferred’ version is displayed.
OK, known issue. Does it matter which one I choose?
Cheers
Martin
That’s a very good question!
In theory, the WASAPI device ‘should’ be better but you have no way of knowing which is which! I will try to hide the detected Windows Multimedia devices as they are considered obsolete.
Has this “undocumented feature” come back in recent versions? I’m seeing it on wfview-master-20220117–03-00-01 (and also 1.2d). See attached.
Hi.
Pretty sure it never went away? It is a QT issue that we have very little control over.
It shouldn’t really matter which one you choose.
