I have a single user account configured in WFView server. My WFView client does not have any authentication information entered in the settings tab (username and password are blank).
That being said, the client still connects to the server and has “Full User” rights (transmit, etc.).
I’ve looked in the ~/.config/wfview/wfview.conf file on the server and there is a username defined with a password set.
I suspect that I know what is causing this. You will most likely have a blank entry in the server setup which is then being compared to the blank username/password in your client. The server doesn’t currently check for blank entries but one is created automatically so there will almost certainly be one. I will fix this before the full release of 1.1.
Regarding blank entries in the server setup, you may be on to something, but… When I look in the Server Setup there aren’t any blank entries; only the one with a username and password. That being said, when I look in the config file, there are blank entries for ServerPassword and ServerUserName. I’ll manually edit those later, restest, and post results.
Thanks… It looks like manually deleting the entries for Server 2 and Server 3 has broken the server capability. My client can no longer connect, regardless of whether I require a password. I guess I’ll look at installing 1.1 and see if that gets things working again.
Hi Dave, if you manually deleted the entries, you must also update ServerNumUsers. If this still doesn’t work, you may need to delete the whole server section from your configuration. It will be re-created once you save wfview configuration again.
