Did fresh compile from source of wfview Release 1 on blank linux Mint 19.2 virtual machine.
Started wfview using mint-menu start icon
Pressed Settings tab
Noticed that “Connect over USB (serial)” is selected by default, and that Radio IP address field is inoperable, which made sense.
additional steps:
Pressed “Connect over LAN”
Observed “Radio IP Address” field became enabled, and accepted typed characters
status:
Could not reproduce. User does not specify operating system, software version, or method of install. Unable to confirm, possibly due to lack of detail.
recommendation:
Ask user for further details on operating system, wfview software version, and method of install. Find out if any USB radios were attached or other relevant hardware.
Hi Elliott, that’s what happens because I retired a year ago, I forgot how to write a bug, sorry. I’m using Win 10 Pro on a desktop PC and Win 10 Home on a laptop PC and experienced the same reported behavior on both PCs. I’m installing version 1.0 from the downloaded Windows Zip file. I do have an IC-7610 connected to the desktop PC but don’t remember whether it was powered on at the time. Can I provide any additional info?
