I did read the Getting Started and have tried all combinations available for USB.
I may be missing somthing but the radio/computer setup works fine for a range of programs including WSJTX, FL-Digi and FreeDV.
On thing confusing form the user manual getting started section is the CV-I USB Port setting on the radio. On my 7300, it can either be Unlink from [REMOTE] or Link to [REMOTE]. A long press brings up a menu with DEFAULT as the only choice. The used manual seems to say the setting should be TRUE. Neither setting works for me.
quote:
For serial port access radios (IC-7300 and basically any radio connected with USB or with a serial port), you will need to set the CI-V “Unlink from [REMOTE] ” to (SET > Connectors > CI-V) true . Next, set the “CI-V USB Baud Rate” to 115200 (required for spectrum access). Finally, enable the “CI-V Transceive ” option, which provides wfview with a telemetry stream from the radio.
End Quite:
Thanks for the reply. Yes, I verified all the radio settings in the slides. The application still will not find the radio. Still works with other apps.
Appears my install didnt go well with my wiin11 machine.
“Got ERROR using COM1 Could not open port please restart”
When I view in Control panel I Got DRIVER did not install.
What am I missing?
Thanks!
73’
