Cant start the script
No output from the command given
I run make inside the directory of the last run and received the following output:
make: Für das Ziel „first“ ist nichts zu tun.
Sorry it says: for the target “first” there is nothing to do.
In which case, it may have built successfully?
Try this command in the same directory
sudo make install
sudo make install
issued some commands and after issuing wfview…the application started inside the terminal.
Many thanks for your continuous help and support
