Hello all,
I’m using wfview 1.1 with my R8600. I have 3 antennas connected to the radio. I have noticed that changing the antenna in wfview does not change the antenna on the radio. Is that a known issue ? i am not sure if it is suppose to work at this point.
Did you ever try it with earlier versions? Just making sure we didn’t break anything. I thought this feature worked but I will have to take a look at it.
1- Confirmed again that in wfview 1.1 changing antenna in the software does not change the antenna on the radio
2- Uninstalled wfview 1.1
3- Installed wfview 1 and confirmed that changing antenna in the software does change the antenna on the radio.
4- Uninstalled wfview 1
5- reinstalled wfview 1.1 and confirmed again that changing the antenna in the software does not change the antenna on the radio
Looking through the code for antenna selection, I suspect that this has never worked? Other rigs with multiple antenna ports also have a dedicated receive antenna (IC7610 and IC785x) and the command that we send to the rig is geared towards this.
I have just looked at the CI-V reference for the ICR8600 and the antenna select command is a single byte (unlike the 2 byte command that we are sending) this is an easy fix and I will make sure that it is in the next 1.2 beta!
That’s interesting, as prior to the RX antenna option that was added in v1.1, wfview was sending what should still be an invalid command for your radio! In v1.0 it sent two bytes, with the second byte always being 0x0. Since 1.1, the second byte should also be 0x0 if you don’t have an RX antenna. Your radio is expecting a single byte though so the behaviour is likely to be ‘undefined’.
