I tried to compile wfview for my RPi Model 3B+. I ffollowed instructions found here:
Commands worked until I got to this one:
make -j
Got a warning message:
…/wfview/resampler/resample.c: In function ‘update_filter’:
…/wfview/resampler/resample.c:675:20: warning: comparison of integer expressions of different signedness: ‘int’ and ‘unsigned int’ [-Wsign-compare]
for (j=0;jfilt_len;j++)
The make continued on until I got these error messages:
g++: fatal error: Killed signal terminated program cc1plus
compilation terminated.
make: *** [Makefile:787: udpserver.o] Error 1
make: *** Waiting for unfinished jobs…
make: *** [Makefile:836: moc_rigcommander.o] Error 1
make: *** [Makefile:808: repeatersetup.o] Error 1
make: *** [Makefile:793: qledlabel.o] Error 1
make: *** [Makefile:768: calibrationwindow.o] Error 1
^Cmake: *** Deleting file ‘moc_rigctld.o’
make: *** Deleting file ‘moc_pttyhandler.o’
make: *** Deleting file ‘moc_qledlabel.o’
make: *** Deleting file ‘moc_meter.o’
make: *** Deleting file ‘moc_udpserver.o’
make: *** Deleting file ‘moc_satellitesetup.o’
make: *** Deleting file ‘moc_calibrationwindow.o’
make: *** Deleting file ‘moc_audiohandler.o’
make: *** Deleting file ‘moc_udphandler.o’
make: *** Deleting file ‘moc_commhandler.o’
make: *** Deleting file ‘rigctld.o’
make: *** Deleting file ‘resample.o’
make: *** Deleting file ‘pttyhandler.o’
make: *** Deleting file ‘meter.o’
make: *** Deleting file ‘audiohandler.o’
make: *** Deleting file ‘udphandler.o’
make: *** Deleting file ‘commhandler.o’
make: *** Deleting file ‘wfmain.o’
make: *** [Makefile:830: moc_wfmain.o] Interrupt
make: *** [Makefile:702: main.o] Interrupt
make: *** [Makefile:724: wfmain.o] Interrupt
make: *** [Makefile:728: commhandler.o] Interrupt
make: *** [Makefile:755: udphandler.o] Interrupt
make: *** [Makefile:763: audiohandler.o] Interrupt
make: *** [Makefile:790: meter.o] Interrupt
make: *** [Makefile:797: pttyhandler.o] Interrupt
make: *** [Makefile:802: resample.o] Interrupt
make: *** [Makefile:821: rigctld.o] Interrupt
make: *** [Makefile:833: moc_commhandler.o] Interrupt
make: *** [Makefile:839: moc_udphandler.o] Interrupt
make: *** [Makefile:842: moc_audiohandler.o] Interrupt
make: *** [Makefile:845: moc_calibrationwindow.o] Interrupt
make: *** [Makefile:848: moc_satellitesetup.o] Interrupt
make: *** [Makefile:854: moc_udpserver.o] Interrupt
make: *** [Makefile:857: moc_meter.o] Interrupt
make: *** [Makefile:860: moc_qledlabel.o] Interrupt
make: *** [Makefile:863: moc_pttyhandler.o] Interrupt
make: *** [Makefile:869: moc_rigctld.o] Interrupt
My RPi is headless. I tried this using VNC in a terminal as well as using ssh. Both gave the same results.
Any suggestions?
