CW speed changes
Wfview 2.03
In the CW panel, I often need to change speeds to match another’s speed. Simply using the up and down does not make an apparent change listening to the local sidetone. However, if I make a speed change AND THEN disable and reenable the sidetone the speed changes. Please change the sidetone speed and of course the remote transceiver speed each time I change the speed without having to disable and reenable the sidetone.
This is likely the same as your other issue. I have identified a situation where if you change the WPM setting in the CW Sender window, the sidetone will not be changed, as the value is updated via a confirmation from the rig, “but” sidetone is only being updated if the value is not the same as the WPM spinbox value.
The next version will handle this correctly.
