Hi Poul,
We’re going to work soon on Dual VFO, Split VFO, Main/Sub, dual waterfall, and satellite mode. It will require a lot of changes so that’s something you can expect in v1.2.
The mouse wheel, in general, is an interesting control, and I think we may need some preferences about wheel-reversal. For example, mouse wheel on the VFO, Waterfall, and various sliders may be inconsistent right now. For the preamp combo box, my scroll happens to be “correct” (that is, as you and I expect it to be, like a knob increasing gain). I definitely want to unify the experience here, so I will look into it.
NB, NR, DSP, Notch, etc, these controls are coming. They will likely live in a separate little window since I want to keep the main UI as uncluttered as possible. But we’ll see. It’s always a balance.
The pull (drag) on the waterfall is tricky! I know a lot of users expect that to work. Presently, if you zoom in to the waterfall (this is an experimental feature, FYI, and it isn’t in the released builds), you can drag the waterfall to pan the display. But getting it so that dragging changes the VFO frequency is a bit more involved, as we have to come up with a pixels/hz number, figure out how many pixels (y direction) the user dragged, and then issue a command. It wouldn’t be “real time” dragging since the change happens after the mouse is released. It’s a feature I’d like but I am struggling on the best way to do it.
The shortcut for 160M is F2, followed by “L”. Think “low band”. I’ll update the docs on that one this weekend.
As for the memory… this is a shortcoming for sure. It will get a re-write once we get some more things done. I’d like it to ultimately be like CHIRP, with a nice spreadsheet view and maybe the ability to manipulate the radio’s memories independently of the computer’s set of memories (but with the same kinds of features).
Documentation: What would you like to see with regards to SSB and Mic options?
Please let us know how your testing goes,
–Elliott
That’s a good 5c, keep it coming.
