Lately for the first time, the program freq. readout seems to bounce
back and forth every few seconds between the correct freq. and a
different freq. (always the same one).
It looks like the problem is totally related to CSVULB which I have always
used with WFView.
Looks like an eibi file is “corrupted”, and that was causing the frequency readout bouncing between thew two values when I selected the lookup option in CSVULB.
You can load it with many different databases, and tune the radio from it.
Lots of other options also.
Also, I use it with WFView. The radio, WfView and CSVUILB all talk with each other very nicely.
If you are not familiar with CSVULV do take a look.
I can guarantee you will like it.
It appears that I had a corrupted eibi file loaded into it, and that was the reason
for the WGFView “bouncing” between the two frequencies.
Re-loaded eibi with a fresh copy, and all well now.
