How to switch between 2 LAN-connected radios easily ?
Have the 7610 and 9700 connected (via a multiport switch) and receive is working well on both. Is there a way to switch between the rigs on the fly ?? Tnx ! REALLY enjoying Wfview thus far !!
Hi Gary.
Due to the differing spectrum sizes of the 7610 and 9700, it isn’t (currently) possible to switch between the two as a restart of wfview is required.
You can however create separate configuration files for each radio and use command line options to run each individually.
https://wfview.org/wfview-user-manual/command-line-arguments/
