Apologies if this has been asked before, but could not find anything when browsing the forum.
I can not connect to my IC-705
It gets an IP from my DHCP 192.168.0.188, and that address can be pinged from any client.
Tested with WIN11 without any success (Release version) I had to install vc_redist manually.
Test on MacOS Monterey (M1) same problem no connection.
User name and password triple checked, CI-V transmit = ON
Tested 1.1 and 1.2 on WIN 11. Only tested 1.1 on OSX
Logfile extract:
1-11-08 17:34:56.427 INF system: “Starting wfview: build ea09647 on Jul 26 2021 at 12:15:01 by phil@Phils-MacBook-Pro-3.local”
2021-11-08 17:34:56.427 INF system: “Operating System: macOS 12.0 (arm64)”
2021-11-08 17:34:56.427 INF system: “Build Qt Version 5.15.2. Current Qt Version: 5.15.2”
2021-11-08 17:34:56.623 WRN qt.qpa.fonts: Populating font family aliases took 97 ms. Replace uses of missing font family “DejaVu Sans” with one that exists to avoid this cost.
2021-11-08 17:34:56.652 INF default: setState 1
2021-11-08 17:34:56.652 INF default: setState 0
2021-11-08 17:34:56.695 INF system: Loading settings from “/Users/maar/Library/Containers/org.wfview.wfview/Data/Library/Preferences/org.wfview.wfview.plist”
2021-11-08 17:34:56.696 INF gui: Got Audio Output: “”
2021-11-08 17:34:56.696 INF gui: Got Audio Input: “”
2021-11-08 17:34:56.696 INF default: Getting server config
2021-11-08 17:34:56.750 INF system: Cannot prepare WF view without rigCaps. Waiting on this.
2021-11-08 17:34:56.751 INF udp: Starting udpHandler user: “maar” rx latency: 150 tx latency: 150 rx sample rate: 48000 rx codec: 4 tx sample rate: 48000 tx codec: 4
2021-11-08 17:34:56.756 INF udp: UDP Stream bound to local port: 53372 remote port: 50001
2021-11-08 17:34:56.767 INF system: Received CommReady!!
2021-11-08 17:35:01.209 INF udp: Closing UDP stream : “192.168.0.1” : 50001
2021-11-08 17:35:01.210 INF udp: Starting udpHandler user: “maar” rx latency: 150 tx latency: 150 rx sample rate: 48000 rx codec: 4 tx sample rate: 48000 tx codec: 4
2021-11-08 17:35:01.212 INF system: Received CommReady!!
2021-11-08 17:35:01.213 INF udp: UDP Stream bound to local port: 64489 remote port: 50001
2021-11-08 17:35:07.204 INF udp: Closing UDP stream : “192.168.0.1” : 50001
