I can select the narrow CW filter from the radios Filter button, but it works only so long as I don’t change operating mode in wfview. If I select LSB/USB and return back to CW, the narrow filter is not selected.
I checked that selecting the narrow filter via CI-V works ok on flrig.
In the IC-718 Advanced Manual on page 5-4 there is the CI-V command “1A 01 31 01” Read/Send Expanded Filter Selection (Narrow) for selecting FL-52A filter.
Hi, yes the filter selection commands must have been there from the start. Why they were not documented then, I don’t know.
What information I have seen about the new model, the only differences I’ve found are the FPGA IF filters, the power connector is different (4-pole) and the DSP option (same as in UT-106?) is fitted as standard.
Another interesting thing is the fact that the ‘new’ manual shows that the IC-718 has the command 1C (PTT on/off) which also wasn’t in the old manual. If this is available on all models. it will allow wfview to control the PTT without DTR/RTS.
All of the rig files are based on the latest published manual for each model (that was available when we wrote them) I wonder how many other ‘undocumented’ commands there are for other radios?
