I’m have a really strange issue.
I have been operating remotely (on LAN) for about a month or so now, and in general have not had any issues until yesterday.
I was operating remotely (via internet) for about 1/2 hour when I suddenly lost my connection. I was unable to reconnect and even had someone try connecting with RS-BA1 ver 2 for me. No joy.
Today I had someone power cycle my radio even thought it appeared to be running just fine (after reconfirming home IP hadn’t changed). I was instantly able to connect up and control the rig. Used it for a bit, then disconnected. I tend to not power down as then I loose my autotuner for the band I’m on and have to very carefully re-tune or loose my amp until it gets reset.
Now, once again I cannot reconnect (and the person who rebooted for me has left for the day.
Below is the log file from my attempts. I have even tried to manually set the CI-V address thinking maybe something went amiss.
I do not think that this is a WFView issue (but it could be), and wonder if anyone else has experienced this and might have a resolution.
Thanks folks and Merry Christmas
Gordon VE7BNR
2021-12-24 11:27:09.680 INF system: “wfview version: 1.2d (Git:b1ef680 on Dec 4 2021 at 16:45:57 by build@wfview.org)\nOperating System: Windows 10 Version 1903 (i386)\nBuild Qt Version 5.15.2. Current Qt Version: 5.15.2\n”
2021-12-24 11:27:09.680 DBG system: "SerialPortCL as set by parser: "
2021-12-24 11:27:09.681 DBG system: "remote host as set by parser: "
2021-12-24 11:27:09.681 DBG system: "CIV as set by parser: "
2021-12-24 11:27:10.699 DBG system: Running with debugging options enabled.
2021-12-24 11:27:10.700 INF default: setState 1
2021-12-24 11:27:10.700 INF default: setState 0
2021-12-24 11:27:11.023 DBG gui: Changed default audio output to: “Headset Earphone (Microsoft LifeChat LX-6000)”
2021-12-24 11:27:11.073 DBG gui: Changed default audio input to: “Headset Microphone (Microsoft LifeChat LX-6000)”
2021-12-24 11:27:11.489 INF system: Loading settings from “\HKEY_CURRENT_USER\Software\wfview\wfview”
2021-12-24 11:27:11.524 INF gui: Got Audio Output: “Headset Earphone (Microsoft LifeChat LX-6000)”
2021-12-24 11:27:11.524 INF gui: Got Audio Input: “Headset Microphone (Microsoft LifeChat LX-6000)”
2021-12-24 11:27:11.536 INF default: Getting server config
2021-12-24 11:27:11.645 INF system: Cannot prepare WF view without rigCaps. Waiting on this.
2021-12-24 11:27:11.645 DBG system: Serial port not specified.
2021-12-24 11:27:11.646 INF udp: Starting udpHandler user: “gbine” rx latency: 150 tx latency: 150 rx sample rate: 24000 rx codec: 4 tx sample rate: 24000 tx codec: 4
2021-12-24 11:27:11.665 INF udp: UDP Stream bound to local port: 51118 remote port: 50001
2021-12-24 11:27:11.742 INF system: Received CommReady!!
2021-12-24 11:27:11.742 INF system: Skipping automatic CIV, using user-supplied value of 152
2021-12-24 11:27:11.742 DBG rig: Final payload in rig commander to be sent to rig:
2021-12-24 11:27:11.743 DBG rig: ---- Begin hex dump -----:
2021-12-24 11:27:11.743 DBG rig: "INDEX: 00 01 02 03 04 05 06 "
2021-12-24 11:27:11.743 DBG rig: "DATA: fe fe 98 e1 19 00 fd "
2021-12-24 11:27:11.743 DBG rig: ----- End hex dump -----
2021-12-24 11:27:11.993 DBG rig: Final payload in rig commander to be sent to rig:
2021-12-24 11:27:11.993 DBG rig: ---- Begin hex dump -----:
2021-12-24 11:27:11.993 DBG rig: "INDEX: 00 01 02 03 04 05 "
2021-12-24 11:27:11.993 DBG rig: "DATA: fe fe 98 e1 03 fd "
2021-12-24 11:27:11.993 DBG rig: ----- End hex dump -----
2021-12-24 11:27:12.492 DBG rig: Final payload in rig commander to be sent to rig:
2021-12-24 11:27:12.492 DBG rig: ---- Begin hex dump -----:
2021-12-24 11:27:12.492 DBG rig: "INDEX: 00 01 02 03 04 05 "
2021-12-24 11:27:12.492 DBG rig: "DATA: fe fe 98 e1 04 fd "
2021-12-24 11:27:12.492 DBG rig: ----- End hex dump -----
2021-12-24 11:27:13.496 DBG rig: Final payload in rig commander to be sent to rig:
2021-12-24 11:27:13.496 DBG rig: ---- Begin hex dump -----:
2021-12-24 11:27:13.497 DBG rig: "INDEX: 00 01 02 03 04 05 "
2021-12-24 11:27:13.497 DBG rig: "DATA: fe fe 98 e1 03 fd "
2021-12-24 11:27:13.497 DBG rig: ----- End hex dump -----
2021-12-24 11:27:13.994 DBG rig: Final payload in rig commander to be sent to rig:
2021-12-24 11:27:13.994 DBG rig: ---- Begin hex dump -----:
2021-12-24 11:27:13.994 DBG rig: "INDEX: 00 01 02 03 04 05 "
2021-12-24 11:27:13.994 DBG rig: "DATA: fe fe 98 e1 04 fd "
2021-12-24 11:27:13.994 DBG rig: ----- End hex dump -----
2021-12-24 11:27:14.491 DBG rig: Final payload in rig commander to be sent to rig:
2021-12-24 11:27:14.491 DBG rig: ---- Begin hex dump -----:
2021-12-24 11:27:14.491 DBG rig: "INDEX: 00 01 02 03 04 05 06 "
2021-12-24 11:27:14.491 DBG rig: "DATA: fe fe 98 e1 14 02 fd "
2021-12-24 11:27:14.491 DBG rig: ----- End hex dump -----
2021-12-24 11:27:14.993 DBG rig: Final payload in rig commander to be sent to rig:
2021-12-24 11:27:14.993 DBG rig: ---- Begin hex dump -----:
2021-12-24 11:27:14.993 DBG rig: "INDEX: 00 01 02 03 04 05 06 "
2021-12-24 11:27:14.993 DBG rig: "DATA: fe fe 98 e1 14 01 fd "
2021-12-24 11:27:14.993 DBG rig: ----- End hex dump -----
2021-12-24 11:27:15.492 DBG rig: Final payload in rig commander to be sent to rig:
2021-12-24 11:27:15.492 DBG rig: ---- Begin hex dump -----:
2021-12-24 11:27:15.492 DBG rig: "INDEX: 00 01 02 03 04 05 06 "
2021-12-24 11:27:15.492 DBG rig: "DATA: fe fe 98 e1 14 03 fd "
2021-12-24 11:27:15.492 DBG rig: ----- End hex dump -----
2021-12-24 11:27:15.992 DBG rig: Final payload in rig commander to be sent to rig:
2021-12-24 11:27:15.992 DBG rig: ---- Begin hex dump -----:
2021-12-24 11:27:15.992 DBG rig: "INDEX: 00 01 02 03 04 05 06 07 "
2021-12-24 11:27:15.992 DBG rig: "DATA: fe fe 98 e1 27 19 00 fd "
2021-12-24 11:27:15.992 DBG rig: ----- End hex dump -----
2021-12-24 11:27:16.304 DBG system: Serial port not specified.
2021-12-24 11:27:16.304 DBG rig: Closing rig comms
2021-12-24 11:27:16.305 INF udp: Closing UDP stream : “209.52.73.81” : 50001
2021-12-24 11:27:16.306 INF udp: Starting udpHandler user: “gbine” rx latency: 150 tx latency: 150 rx sample rate: 24000 rx codec: 4 tx sample rate: 24000 tx codec: 4
2021-12-24 11:27:16.308 INF system: Received CommReady!!
2021-12-24 11:27:16.308 INF system: Skipping automatic CIV, using user-supplied value of 152
2021-12-24 11:27:16.308 DBG rig: Final payload in rig commander to be sent to rig:
2021-12-24 11:27:16.308 DBG rig: ---- Begin hex dump -----:
2021-12-24 11:27:16.308 DBG rig: "INDEX: 00 01 02 03 04 05 06 "
2021-12-24 11:27:16.308 DBG rig: "DATA: fe fe 98 e1 19 00 fd "
2021-12-24 11:27:16.308 DBG rig: ----- End hex dump -----
2021-12-24 11:27:16.313 INF udp: UDP Stream bound to local port: 65357 remote port: 50001
2021-12-24 11:27:16.554 DBG rig: Final payload in rig commander to be sent to rig:
2021-12-24 11:27:16.554 DBG rig: ---- Begin hex dump -----:
2021-12-24 11:27:16.554 DBG rig: "INDEX: 00 01 02 03 04 05 "
2021-12-24 11:27:16.554 DBG rig: "DATA: fe fe 98 e1 0f fd "
2021-12-24 11:27:16.554 DBG rig: ----- End hex dump -----
2021-12-24 11:27:16.554 DBG rig: "INDEX: 00 01 02 03 04 05 06 07 08 "
2021-12-24 11:27:16.554 DBG rig: "DATA: fe fe 98 e1 1a 05 00 46 fd "
2021-12-24 11:27:17.057 DBG rig: Final payload in rig commander to be sent to rig:
2021-12-24 11:27:17.057 DBG rig: ---- Begin hex dump -----:
2021-12-24 11:27:17.057 DBG rig: "INDEX: 00 01 02 03 04 05 06 07 "
2021-12-24 11:27:17.057 DBG rig: "DATA: fe fe 98 e1 27 10 01 fd "
2021-12-24 11:27:17.058 DBG rig: ----- End hex dump -----
2021-12-24 11:27:17.554 DBG rig: Final payload in rig commander to be sent to rig:
2021-12-24 11:27:17.554 DBG rig: ---- Begin hex dump -----:
2021-12-24 11:27:17.554 DBG rig: "INDEX: 00 01 02 03 04 05 06 07 "
2021-12-24 11:27:17.554 DBG rig: "DATA: fe fe 98 e1 27 11 01 fd "
2021-12-24 11:27:17.554 DBG rig: ----- End hex dump -----
2021-12-24 11:27:18.054 DBG rig: Final payload in rig commander to be sent to rig:
2021-12-24 11:27:18.054 DBG rig: ---- Begin hex dump -----:
2021-12-24 11:27:18.054 DBG rig: "INDEX: 00 01 02 03 04 05 06 "
2021-12-24 11:27:18.054 DBG rig: "DATA: fe fe 98 e1 1b 00 fd "
2021-12-24 11:27:18.054 DBG rig: ----- End hex dump -----
2021-12-24 11:27:18.557 DBG rig: Final payload in rig commander to be sent to rig:
2021-12-24 11:27:18.557 DBG rig: ---- Begin hex dump -----:
2021-12-24 11:27:18.557 DBG rig: "INDEX: 00 01 02 03 04 05 06 "
2021-12-24 11:27:18.557 DBG rig: "DATA: fe fe 98 e1 1b 01 fd "
2021-12-24 11:27:18.557 DBG rig: ----- End hex dump -----
2021-12-24 11:27:19.555 DBG rig: Final payload in rig commander to be sent to rig:
2021-12-24 11:27:19.555 DBG rig: ---- Begin hex dump -----:
2021-12-24 11:27:19.556 DBG rig: "INDEX: 00 01 02 03 04 05 06 "
2021-12-24 11:27:19.556 DBG rig: "DATA: fe fe 98 e1 16 5d fd "
2021-12-24 11:27:19.556 DBG rig: ----- End hex dump -----
2021-12-24 11:27:20.055 DBG rig: Final payload in rig commander to be sent to rig:
2021-12-24 11:27:20.055 DBG rig: ---- Begin hex dump -----:
2021-12-24 11:27:20.055 DBG rig: "INDEX: 00 01 02 03 04 05 "
2021-12-24 11:27:20.055 DBG rig: "DATA: fe fe 98 e1 12 fd "
2021-12-24 11:27:20.055 DBG rig: ----- End hex dump -----
2021-12-24 11:27:20.557 DBG rig: Final payload in rig commander to be sent to rig:
2021-12-24 11:27:20.557 DBG rig: ---- Begin hex dump -----:
2021-12-24 11:27:20.557 DBG rig: "INDEX: 00 01 02 03 04 05 "
2021-12-24 11:27:20.557 DBG rig: "DATA: fe fe 98 e1 11 fd "
2021-12-24 11:27:20.557 DBG rig: ----- End hex dump -----
2021-12-24 11:27:21.057 DBG rig: Final payload in rig commander to be sent to rig:
2021-12-24 11:27:21.057 DBG rig: ---- Begin hex dump -----:
2021-12-24 11:27:21.057 DBG rig: "INDEX: 00 01 02 03 04 05 06 "
2021-12-24 11:27:21.057 DBG rig: "DATA: fe fe 98 e1 21 01 fd "
2021-12-24 11:27:21.057 DBG rig: ----- End hex dump -----
2021-12-24 11:27:21.554 DBG rig: Final payload in rig commander to be sent to rig:
2021-12-24 11:27:21.554 DBG rig: ---- Begin hex dump -----:
2021-12-24 11:27:21.554 DBG rig: "INDEX: 00 01 02 03 04 05 06 "
2021-12-24 11:27:21.554 DBG rig: "DATA: fe fe 98 e1 21 00 fd "
2021-12-24 11:27:21.554 DBG rig: ----- End hex dump -----
2021-12-24 11:27:22.057 DBG rig: Final payload in rig commander to be sent to rig:
2021-12-24 11:27:22.057 DBG rig: ---- Begin hex dump -----:
2021-12-24 11:27:22.057 DBG rig: "INDEX: 00 01 02 03 04 05 06 "
2021-12-24 11:27:22.057 DBG rig: "DATA: fe fe 98 e1 14 07 fd "
2021-12-24 11:27:22.057 DBG rig: ----- End hex dump -----
2021-12-24 11:27:22.556 DBG rig: Final payload in rig commander to be sent to rig:
2021-12-24 11:27:22.556 DBG rig: ---- Begin hex dump -----:
2021-12-24 11:27:22.556 DBG rig: "INDEX: 00 01 02 03 04 05 06 07 "
2021-12-24 11:27:22.556 DBG rig: "DATA: fe fe 98 e1 27 14 00 fd "
2021-12-24 11:27:22.556 DBG rig: ----- End hex dump -----
2021-12-24 11:27:23.056 DBG rig: Final payload in rig commander to be sent to rig:
2021-12-24 11:27:23.056 DBG rig: ---- Begin hex dump -----:
2021-12-24 11:27:23.056 DBG rig: "INDEX: 00 01 02 03 04 05 06 07 "
2021-12-24 11:27:23.056 DBG rig: "DATA: fe fe 98 e1 27 15 00 fd "
2021-12-24 11:27:23.056 DBG rig: ----- End hex dump -----
2021-12-24 11:27:24.554 DBG rig: Final payload in rig commander to be sent to rig:
2021-12-24 11:27:24.554 DBG rig: ---- Begin hex dump -----:
2021-12-24 11:27:24.554 DBG rig: "INDEX: 00 01 02 03 04 05 "
2021-12-24 11:27:24.554 DBG rig: "DATA: fe fe 98 e1 03 fd "
2021-12-24 11:27:24.554 DBG rig: ----- End hex dump -----
2021-12-24 11:27:25.056 DBG rig: Final payload in rig commander to be sent to rig:
2021-12-24 11:27:25.056 DBG rig: ---- Begin hex dump -----:
2021-12-24 11:27:25.056 DBG rig: "INDEX: 00 01 02 03 04 05 "
2021-12-24 11:27:25.056 DBG rig: "DATA: fe fe 98 e1 04 fd "
2021-12-24 11:27:25.056 DBG rig: ----- End hex dump -----
2021-12-24 11:27:26.054 DBG rig: Final payload in rig commander to be sent to rig:
2021-12-24 11:27:26.054 DBG rig: ---- Begin hex dump -----:
2021-12-24 11:27:26.054 DBG rig: "INDEX: 00 01 02 03 04 05 "
2021-12-24 11:27:26.054 DBG rig: "DATA: fe fe 98 e1 03 fd "
2021-12-24 11:27:26.054 DBG rig: ----- End hex dump -----
2021-12-24 11:27:26.555 DBG rig: Final payload in rig commander to be sent to rig:
2021-12-24 11:27:26.555 DBG rig: ---- Begin hex dump -----:
2021-12-24 11:27:26.556 DBG rig: "INDEX: 00 01 02 03 04 05 "
2021-12-24 11:27:26.556 DBG rig: "DATA: fe fe 98 e1 04 fd "
2021-12-24 11:27:26.556 DBG rig: ----- End hex dump -----
2021-12-24 11:27:27.055 DBG rig: Final payload in rig commander to be sent to rig:
2021-12-24 11:27:27.055 DBG rig: ---- Begin hex dump -----:
2021-12-24 11:27:27.055 DBG rig: "INDEX: 00 01 02 03 04 05 06 "
2021-12-24 11:27:27.055 DBG rig: "DATA: fe fe 98 e1 14 02 fd "
2021-12-24 11:27:27.055 DBG rig: ----- End hex dump -----
2021-12-24 11:27:27.557 DBG rig: Final payload in rig commander to be sent to rig:
2021-12-24 11:27:27.558 DBG rig: ---- Begin hex dump -----:
2021-12-24 11:27:27.558 DBG rig: "INDEX: 00 01 02 03 04 05 06 "
2021-12-24 11:27:27.558 DBG rig: "DATA: fe fe 98 e1 14 01 fd "
2021-12-24 11:27:27.558 DBG rig: ----- End hex dump -----
2021-12-24 11:27:28.057 DBG rig: Final payload in rig commander to be sent to rig:
2021-12-24 11:27:28.057 DBG rig: ---- Begin hex dump -----:
2021-12-24 11:27:28.057 DBG rig: "INDEX: 00 01 02 03 04 05 06 "
2021-12-24 11:27:28.057 DBG rig: "DATA: fe fe 98 e1 14 03 fd "
2021-12-24 11:27:28.058 DBG rig: ----- End hex dump -----
2021-12-24 11:27:28.555 DBG rig: Final payload in rig commander to be sent to rig:
2021-12-24 11:27:28.555 DBG rig: ---- Begin hex dump -----:
2021-12-24 11:27:28.555 DBG rig: "INDEX: 00 01 02 03 04 05 06 07 "
2021-12-24 11:27:28.555 DBG rig: "DATA: fe fe 98 e1 27 19 00 fd "
2021-12-24 11:27:28.555 DBG rig: ----- End hex dump -----
