Xmit audio comes from radio mic even with PC mic selected as source in Wfview settings.
PC is connected to IC-9700 via LAN and works fine otherwise.
PC mic tests OK and is working with other programs
Is there some setting I don’t see in IC-9700 for transmit audio source?
Look for the mod source selection. Change it from Mic over to LAN. (Assuming you are connecting over a network.)
If you are referring to setting in the program, yes, it was on LAN. But somehow, checking and re-doing settings over and over, it has started working. Great! But now I don’t know why it didn’t work before.
Thank you for your help.
that is called magic…
