Hi There, Ive installed the WFView software on 2 different laptops but I cant select any Audio devices. The boxes are blank. Ive installed VB Cable too. Everything else seems to work fine. Even WSJT-X also works fine through the virtual com port but obviously no audio. Any ideas ?
We haven’t seen this on any of the machines that we have tested Windows 10 with, if the boxes are blank it means that Qt has been unable to enumerate your audio devices.
Can you take a look at the log file on both machines Log file | wfview and post any messages that begin ‘audio’?
Hi Phil, Thanks for the prompt reply.See below for the log.
PS C:\WINDOWS\system32> Get-Content $env:TEMP\wfview.log -Wait -Tail 30
2021-05-11 09:09:32.361 DBG audio: Format not supported, choosing nearest supported format - which may not work!
2021-05-11 09:09:32.361 DBG audio: Output reinit() running
2021-05-11 09:09:32.361 DBG audio: Output start() running
2021-05-11 09:09:32.361 WRN default: using null output device, none available
2021-05-11 09:09:32.361 DBG audio: Output flush() running
2021-05-11 09:09:32.362 WRN default: using null output device, none available
2021-05-11 09:09:32.362 DBG audio: Output wf_resampler_init() returned: 0 ratioNum 1 ratioDen 1
2021-05-11 09:09:32.362 DBG audio: Output audio port name: “”
2021-05-11 09:09:32.366 DBG audio: Input chunkSize: 1920
2021-05-11 09:09:32.367 DBG audio: Input device “” not found, using default
2021-05-11 09:09:32.367 DBG audio: Input setDevice() running : “”
2021-05-11 09:09:32.368 DBG audio: No audio device was found. You probably need to install libqt5multimedia-plugins.
2021-05-11 09:09:32.369 DBG audio: Format not supported, choosing nearest supported format - which may not work!
2021-05-11 09:09:32.369 DBG audio: Input reinit() running
2021-05-11 09:09:32.369 DBG audio: Input start() running
2021-05-11 09:09:32.369 WRN default: using null input device, none available
2021-05-11 09:09:32.369 DBG audio: Input flush() running
2021-05-11 09:09:32.369 DBG audio: Input wf_resampler_init() returned: 0 ratioNum 1 ratioDen 1
2021-05-11 09:09:32.370 DBG audio: Input audio port name: “”
2021-05-11 09:09:32.713 DBG rig: Using incomingCIVAddr: (int): 164 hex: a4
2021-05-11 09:09:32.713 DBG rig: Have rig ID: decimal: 164
2021-05-11 09:09:33.504 DBG rig: Received 0x15 center span data: for frequency 100000
2021-05-11 09:10:18.147 DBG udp: Closing UDP stream : “192.168.59.1” : 50003
2021-05-11 09:10:18.148 DBG udp: Closing UDP stream : “192.168.59.1” : 50002
2021-05-11 09:10:18.150 DBG udp: Sending token removal packet
2021-05-11 09:10:18.150 DBG udp: udpHandler Sending Token request: 1
2021-05-11 09:10:18.150 DBG udp: Closing UDP stream : “192.168.59.1” : 50001
Yes it definitely seems not to be finding any audio devices on your computer. Can you let me know what make/model the computer is and what sound device you are using as this is very strange?
Hi Phil. Ive been messing about with this all day and have now got it to work. My guess is that the drivers for the Audio devices on both Laptop’s had got messed up. Ive un-installed all drivers etc and re-installed again. All seems ok at the moment. For the record they are Realtek Audio Drivers. I guess its just my luck that I had the same drivers on 2 different laptop’s ! Also what helped was using the new version you have just uploaded. Does the Software have an “ini” file type thing that once generated it keeps using that for start up reference ? Cheers for you help anyway. James G1JSP
Hi James.
That’s great news, I thought it would be something like that, but the fact that it happened on two machines suggested otherwise.
wfview uses the Qt preferences systems which in Windows, stores everything in the Windows Registry. This is described in more detail in Preferences File | wfview as always, when editing the Registry, always have a backup!
The second release of wfview should have multiple rig management and a re-vamped user interface.
