Hi, I know this is a pretty old rig but was wondering if you guys had plans for supporting it. I briefly tried thinking it might work but no joy
Hi Kevin,
Can you bring it by for testing?
Most likely, all you would need to do is set the CI-V address on the radio to a similar model that we already support, and then manually specify it in wfview and check the box “Use as Model ID too”.
I have not looked at what commands that particular radio has. Many rigs from that era support only frequency, mode, and some memory-related commands. But sometimes you find one with s-meter or other functions.
If you follow our guide on using older radios, and get the radio to “fake” being one of these radios:
Then you will probably have some success.
I’ve been told I have an older radio obsession. So don’t be shy, let me know how it goes, we’ll get it.
Ok, just read over the manual for that rig. The CI-V address is set by removing or adding diodes on a circuit board. So… you’re probably in no hurry to get in there and set it up to look like a different (but supported) rig.
If you can find any kind of data about what commands are supported over CI-V, then I can add them the next time I am working on the rig identity code.
Until then, you can try manually specifying the default CI-V address in wfview as 0xEH
. That may do the trick enough. Make sure to set the correct baud rate, the default is probably 1200 bps. Press “Save Settings”, close wfview, and re-open. See if that works.
