icom r8600
hi
i have icom r-8600 but when i want use port 50001 its closed with nmap test
icant connect to radio with vb.net
please help me
is the network enabled?
using the right settings in the 8600?
does it reply to icmp?
what nmap command did you exec?
net is enable i want connect and control r8600 programically with vb.net
now let’s try to answer the other three questions…
to troubleshoot things you need to find out first if it would work for a start
using simple checkes before you add another variable thing, like vb.net
(apart from: what has this to do with wfview)
If you are writing your own application to control the R8600 be advised that it is a tricky protocol:
You might have better luck installing wfview and then using one of wfview’s simpler interfaces such as the raw TCP port or the virtual serial port or the rigctld-compatible TCP interface.
