Under Linux, in this case Ubuntu Impish, the main UI screen doesn’t properly render and can’t be resized to correct for the improperly drawn elements. I think this may be because with the IC-7100 there is no waterfall/panadapter view to show. I thought this might be addressed somewhere else but I can’t find a reference to it. Hopefully I’m not the only one experiencing this problem. A screenshot of my wfview instance is shown below. Let me know if there’s anything else I can add to help address this problem.
I have same issue on Windows 10, as well as on a raspberry Pi using IC 7000. The main operating screen cannot be resized whereas the other screens can be resized, including full screen. When fullscreen is selected the window on the main sreen is indexed to upper left corner but the image is not enlarged. All other screen operate normally.
These lines are around line 868 or so in wfmain.cpp. The reason for the two sizes is that I had trouble getting the “fixed” size policy to fix at any particular size, and this was the recommended fix (no pun intended!) on the qt forums.
If you find a good size, let me know and we’ll use it!
How does the Settings tab look to you with these settings? It seems squished to me. I may need to look at how to set that size policy different on that tab.
