for me the installation under Linux Mint 21 fails.
I get the following error message:
In file included from …/wfview/audiohandler.h:32,
from …/wfview/udphandler.h:27,
from …/wfview/rigcommander.h:11,
from …/wfview/wfmain.h:24,
from …/wfview/main.cpp:14:
…/wfview/audioconverter.h:17:10: fatal error: eigen3/Eigen/Eigen: Datei oder Verzeichnis nicht gefunden
17 | #include <eigen3/Eigen/Eigen>
compilation terminated.
make: *** [Makefile:961: main.o] Fehler 1
make: *** Auf noch nicht beendete Prozesse wird gewartet …
Error in make step.
wfview was not compiled.
does anyone know this problem
is there a solution ?
the information from Elliott is important!
I reinstalled Linux Mint 21 a few days ago and wfview works great whether it’s via usb or wifi.
See also Thread “WFview Server” from April 1 and my post from 30. April 2022…
I’m glad it is working! If you can share the errors that would be helpful; I do not have a computer with Mint 21 and I’m guessing some of the packages have slightly different names. My main machine is Mint 20.
Let us know how it goes, very interested in your feedback,
as I wrote above, I had to install the following files manually:
libeigen3-dev, libportaudio2, libportaudiocpp0,
portaudio19-dev, librtaudio-dev and librtaudio6
meanwhile installed wfview on my desktop, where the script ran without any problems.
my desktop is also linux mint 21,all updates for mint 21 were carried out before the installation of wfview, unfortunately i can’t submit any error messages for the installation on my laptop because i deleted everything when closing the command prompt.
but since the installation worked perfectly on my desktop, I assume that there was a problem with my laptop and not a general problem with the installation of wfview.
