Just trying to learn, so admittedly this might be a dumb question.
Trying to connect again over LAN.
Have NETWORK box checked in Settings,
As I mentioned, when I put the correct IP address in yesterday, everything worked fine.
This morning not the case.
I entered the IP address (…122), but would not start.
But- With a bit of "fiddling, I did get it working.
However, when I go to the Radio Status box, I see …142 for User IP Address.
NOT THE .122 that the radio shows for the IP address, and also in the Settings tab for Network
What is likely happening ? Is it actually connecting thru LAN, or possibly using the USB instead ?
What am I doing incorrectly (as usual) ?
Bob
