is there a way to display the transmitted ALC when in SSB mode?
Can be displayed.
1.Settings → Meater Selectton:
Select ALC from the pull-down list
2.ALC is displayed in View.
looks like I need to update, I dont see that on my version UPDATE looks like I have the latest version, and I dont see that option using my 7610
it’s in for a while already to be honest.
Date: Mon Aug 23 14:40:36 2021 -0700
Now with dual meters for everyone!
so if possibe, update yes. (what’s your version?)
On a sidenote – I would choose SWR instead. ALC is a single set and forget thing on th erig itself – if you stay within the range as stated in the manual – you are good to go. Note that ICOMs ALC is different from some othe rmakes where ALC deflection is a NO-GO. In the ICOM case it’s totally fine.
Hi Jamie,
you might see this under Settings → Radio Settings, if you are running a very recent version with the revamped settings tab.
Send us a screenshot if in doubt.
