Good morning all, I looked at this software when it first came out and at that time I got the icom software working. Today the icom crashed and won’t work so I spent a little time getting this going.
I have it set up and working for my 9700 and need some time to learn it.
My question is do I install a second copy into a
Different folder for my 7300?
Sorry for the bad spelling and caps, I am typing with big thumbs on an iPhone
The best way to work with multiple radios is to run wfview with the --settings command line argument:
wfview --settings rigname.ini
Once done, this will create a configuration file called rigname.ini and you can configure everything for that particular rig then click ‘save’. If you then run with a different .ini filename, you can do the configuration for your other rig.
Once done, you can create shortcuts that include the --settings argument for each rig.
Thanks Phil that worked. I have the 9700 all
Set up and working. I set the server up for the 7300 but can’t figure out how to get that to connect remotely yet.
