I’m new to Wfview. I have the client working on my Windows 11 laptop. Everything functioning as expected except no audio from IC7300 to laptop?
Running WSJT-X everything works normal…
Any suggestions and many thanks in advance.
Hi Eddy.
With the IC7300 as the only connection option is USB, wfview doesn’t handle audio. Any audio will come into your PC via the USB codec. The only exception is if you are using wfview server, you then need to select the USB audio devices within the server configuration.
