If the radio is fully powered off, then wfview’s “authorization token” that the radio gives out is probably invalid when the radio turns back on. We don’t have any way to really work around that situation other than you disconnecting and re-connecting.
The way I would accomplish what you are doing, is to use the “Power Off” button inside wfview, and, to make sure the radio’s “network” menu setting has “Power OFF Setting (for Remote Control)” set to “Standby/Shutdown”.
With the above mentioned setting enabled, and using the Power Off button inside wfview, I can shut down my IC-9700 (similar to your 8600) remotely from my bedroom. I can then press Power On in wfview to power the radio back on, or, I can even close wfview, put the computer to sleep, open wfview again, and press “Power On” to revive the radio. Keep in mind we have a (long) 3 second delay on power up in wfview, so when you press Power On, it’ll seem somewhat unresponsive for a few seconds while the radio comes up.
I guess the only edge case there is if you have wfview open, Power Off the radio, and then sleep the computer. I’d try it but I’ve got 50,000 things open on my computer right now that I want to finish first:-). If you are in wfview and the Power On button isn’t working, you can try going to Settings, and pressing Disconnect, followed by Connect.
In summary:
Set the radio to “Standby/Shutdown” rather than “Shutdown”
Make use of the Power On and Power Off buttons inside wfview
If it’s really stuck, try Disconnect followed by Connect
Let us know if this helps, and here is an image I stole off a youtube video showing the menu on the IC-9700. I imagine it’s almost the same on the IC-R8600.
That flashing amber LED simply signifies that the radio is in standby mode, similar to how a TV or stereo works.
This allows the radio to keep only the USB and network active while shutting-down all other parts, allowing wfview to connect and initiate a ‘power on’ command.
Glad it worked! The slow red light just means the rig is in low power standby mode. In this mode, it seems like about half the brain is on and the rest of the radio is powered down, including all the analog stuff. But I really don’t know, it’s a better question for Icom honestly.
If you’re like me and flashing lights annoy you, stick a carefully-cut rectangle of black electrical tape over the LED slot.
Luckily the color ir not blue because that is really an anoying color in your face. I have a card reader at work that has a blue led but the issue is that the whole plastic holder is translucent so even if you tape off the outside…
Using latest version on W10 pc.
Works just great.
You folks did a truly terrific job with it.
Thought it would be fun to try it out on my Mac. Running Monterey
All sorts of problems. Previous version worked.
I can’t get it to install.
Msg’s come up saying: This software needs to be updated. Contact the developer for more information.
and, “wfview” can’t be opened because Apple cannot check it for malicious software.
Also seems to want to use a program I am not familiar
with to extract the zip : Unarchiver
What am I, as usual, doing wrong ?
Step by step on how to do it would be great. (or, perhaps, a download link I should use instead ?)
I apparently miss many of the “nuances” these days; old age problem.
