I’m trying to set up my LAN for port forwarding. What should the radio show up as in my connected device list? My 7610 is going through a wifi repeater RJ-45 connection.
John N1JM
John N1JM
Hi John,
Check the radio’s menu and see if it will tell you the IP address of the radio. That is what I would use.
Also on your WiFi router - try to set the ic-705 to a static ip so it doesn’t change periodically
