I have been trying to use the remote server function to have Ubuntu connect to the 705 via wifi and have the same box serve the radio to multiple clents. It connects ok to the 705 but will not respond to connection requests. I have set wfview to enable its server and listen on 60001,2,3 and the remote client is set the same. Can someone please point me a better direction?
We disabled the built-in server when wfview is connected to a radio over lan, because a lot of users seemed to think it was required to run the server to do LAN connections.
However… wfview does in fact work this way. We’ll re-enable the server for LAN connections and try and make it more clear what the server is for.
