Thank you for your last note it was very helpful. The simple statement " you cannot set this parameter while anyone is connected, so be sure to save the settings and re-launch wfview just to make sure nobody is connected when the change happens.
I had been making the changes to the settings and had to continuously check and recheck them as they didn’t change.
I did make the changes and also found the sequence in which I brought up the system made the difference.
I had both the client and server working last night and shut it all down and brought it all back up today and it worked.
So I tried it again and shut it down and brought it back up just a coupld of minutes ago and it again worked.
I am going to use this configuration for a few days but my ultimate goal is to use the software in another state and need the directions on how to set it up
Thank you again for your patience and guidance
