Hello,
Wonderful program. Thanks so much for making it available.
Using with a R8600 and W10.
Probably another dumb thing I’m missing, but a bit stumped.
I have Center selected for the Spectrum Mode.
Shows up just the way you would expect on the radio display.
But on wfview, apparently not.
Shows 0.6 to 1.1 on the x axis.
Cycling between Center and Fixed does nothing.
Seems to be “locked” in Fixed in the program.
Can you confirm to me what version of wfview you are using? The “About” button will bring up the about box, and it will say “wfview version XXX” under the logo, and at the bottom of the about box, “Build YYYYYY on Date”. I want to make sure you have the latest version.
When the spectrum shows 0.6 to 1.1, do you get any kind of spectrum image, or is it blank? I assume blank.
Can you confirm:
Bottom-right corner says “R8600” and does not show “NONE”
Radio has CI-V Transceive turned ON (double-check)
You have NOT defined a manual CI-V address in the wfview setup.
