Hello,
Is there any correlation between what shows in
the radio for the various signal strength meter
readings, e.g. dBm, and THE WfView vertical axis scale (set now from 0 to 150) ?
Bob
Hello,
Bob
Hi Bob,
Tested this on 14 MHz for you.
-33 dBm, preamp off in the R8600 gives a top level of 160 on the wfview vertical scale and -73 dBm shows 80 on the scale. -107 dBm is just visible, and switching on the preamp it shows about 58.
Hope this helps.
73,
Peter
Hi
Sure does.
Much thanks,
Bob
