Hi Roeland. Thanks for the ‘don’t ask again’ checkbox. In windows you just use the lower right corner of the window to size, but now it only gets so small and doesn’t fit on my crowded screen as well as ver 1.0 did, so something is different.
I had the same issue Uli reported on Linux Mint 20.2 with the
precompiled binary. The fullbuild script worked without issue. I tested
on an R-8600 RX and an IC-7610 TRX over LAN and an IC-705 over WLAN.
Switching from one to the other over LAN/WLAN was merely changing the IP and a
disconnect and connect cmd. Nice job!
I have now two versions - one for extreme new versions and one for older versions of the OS.
Thinking of how to distribute that – you need “the other version” only if it segfaults at start.
