Torben
(Torben Petersen)
12 July 2021 13:20
#1
I have a LAN connections over Wifi from Icom IC 705 to the PC.
Command and Audio works perfect.
But i want to use HRD (last update) DM780 and Log prg in use.
Is i possible to use this programs also together .
In my settings in HRD is CI-V = Port 4 and Audio = Ser port 5
eliggett
(Elliott Liggett)
12 July 2021 17:07
#2
Hi Torben,
Yes, you can share control with a second program. On windows, this involves setting up a “virtual” serial loopback from wfview into HRD.
Here is a section from the user manual on this topic:
https://wfview.org/wfview-user-manual/sharing-control/
There’s also this video , where it is shown how to run wfview with wsjt-x. You can follow the basic directions for setup, with HRD it requires the same changes to wfview and your system.
