Hearing is not what it used to be, and would love to be able to
enhance (boost) the treble/higher freq’s even more than what the
radio natively allows.
A “simple” Audio eq. would be great, if feasible.
BTW: Any suggestions from anyone for a really very simple audio eq., with the added requirement that it be small and not take up much screen space ?
If it is windows this works great and it’s free! FxSound installs like a driver between the computer and sound card. It has worked with every sound card I have tried. including including external USB SCs. I have two USB sticks, one for my speakers and another for the headset. I can switch between sound cards and no problem with using FxSound. It gives you a full equalizer with presets as well as letting you to create and save your own presets. It also lets you boost the volume along with other other settings.
The reason I was hoping that a simple audio eq. could be added directly
into the program, is my inability so far to find an external
equal. that does not take up a “substantial” amount of room on my monitor.
I use WFView now with CSVULB, so there’s not much left.
I really need only a very basic equal. that will allow for “some” boosting
at the high end. Really don’t need one with 20 sliders, etc.
And, as noted, a very small footprint.
Thanks for the suggestions, and will certainly look at
FxSound.
As always, thanks for thoughts, suggestions, and comments.
Really appreciated.
I should have mentioned that I am operating my radio remotely so the audio is coming from my computer. Thus in my situation, the comes from my computer so FxSound works fine for me.
