I had a problem after running WFview without a USB cable sucessfully when I disconnected and went to use the IC-705 on its own. I had no SSB output using the mike PTT. Should I have turned off the WLAN to gain complete control of the radio without WFview? VO1OK
Using the 705 on its own, you will need to set the modulation source back to “Mic” instead of “LAN” or “USB”. Same applies to the other supported rigs.
Thanks for the help Elliot
