This works great and have used it from several locations. Just curious but when I set up a demo for local hams on a school network, it would not update. I tried using a cell phone hot spot with same result. I closed the notebook and when opening the next morning at a different location it worked fine. Something about that location? My solution … stay away from that place. If you have another one let me know.
Hi Bill,
Some networks are picky! Assuming you have the IP address set properly, you can try changing the server-side ports, and then changing wfview to match. Remember that there are three ports.
Also, software demos. Pretty much how they go!
