I’m running 1.64 on my Win10 PC at home, connected to my 7300.
I’m running 1.64 on my MBP Monterey 12.6.6.
On my remote computer, I’m receiving audio, and receiving frequency and other settings FROM the radio just fine. I am unable to change frequency, transmit, and I’m not seeing any waterfall activity.
I did a desktop remote to my win10pc and I can change frequency and transmit from the WFView connected to the radio there, and it receives the audio from my remote PC.
It seems strange to me that I can receive data from the server pc, but not send.
I just tried to exit and restart the app on my remote, and now have no audio. Sometimes I have receive audio on remote, sometimes I don’t. Haven’t really figured that out.
Getting a lot of these messages in the log:
2023-07-24 13:03:52.159 INF rig: Warning: Spectrum sequence max was zero, yet spectrum was received.
2023-07-24 13:03:52.166 INF rig: Warning: Spectrum sequence max was zero, yet spectrum was received.
2023-07-24 13:03:52.206 INF rig: Warning: Spectrum sequence max was zero, yet spectrum was received.
2023-07-24 13:03:52.211 INF rig: Warning: Spectrum sequence max was zero, yet spectrum was received.
This is most common if wfview isn’t able to auto detect the rig type. You MUST enable C-IV transceive on your IC7300 and leave the C-IV address on both the server and client to auto, do NOT manually configure the C-IV address.
Ok, I guess “Auto” is unchecking the box? If so, after doing that, it didn’t work at all.
I did set to manual and radio 94 on both server and client, now it is working.
No it is C-IV transceive, not C-IV itself (which you can’t really disable), this is a specific feature that will automatically broadcast frequency/mode changes that wfview relies on for proper operation.
Certain software will attempt to disable it because they can’t handle unsolicited data.
Yes, CI-V Transceive is the setting I enabled a few weeks ago.
Today I could transmit from the wfview server instance, but not the remote. As soon as I entered 94 in the address of the remote, then it worked. If i unchecked the manual address setting, wfview didn’t read anything from the radio.
note also that some other programs need to have CI-V off and may even force this to be off when used.
It has to do with the fact that older programs may not easily handle nsollicited data from the rigs.
WFVIEW can do without issues and in fact benefits from CI-V transceive being on.
Also be sure that you always have the baudrate set up correct as well as things like unlink-from-remote. If you fail to do so, you will not have scope data either.
Ok so it appears that if CI-V Transceive is off, I can still use WFView locally to transmit, get scope data, etc, all works fine locally, but all things doesn’t work remotely until it is turned on.
It appears that when I run Log4OM, it’s turning this setting off. I will have to look to see which rig control interface it’s using. What’s additionally frustrating about that, if I turn cat control OFF in Log4OM, it’s not letting go of the transceiver, so I have to completely exit the program, run WFView, then run log4om without enabling cat control.
Thanks for all your responses, at least I know what’s going on now. I know I turned that setting on long ago, but didn’t realize the logger was turning it back off.
