Have 2.0 up and running on my IC-7300. Working great, with no real issues.
When I turn on the pre-amp, I am not able to turn it off again with the SW. Also, I am not able to turn on the attenuator with the SW.
Anyone know if I am missing something, or is it supposed to work this way? I have to use the radio front panel to turn off pre-amp or use attenuator
I am due to test my IC-7300 soon, so I will check this (although it should work?). There are known issues with CW Sender and ATU as I missed those commands off when I created the IC-7300.rig file, but preamp/attentuator should work, so I will definitely look at those.
Just checked, and I have missed the PREAMP OFF option so that explains why that isn’t working, and I had mistakenly used 10dB for the Attenuator instead of 20dB. These are both corrected in the attached IC-7300.rig file.
Please replace the file in [wfview directory]\rigs (this is usually c:\Program Files\wfview\rigs but you may have changed this when installing).
Make sure you replace the file as multiple files with the same Rig ID will overwrite each other.
Thank you for your renew
I was download the latest wfview 2.0 on the offical download website, i want to ask that,does the official download file is the new one? Or i should use your new rigfile to replace the file from the old one?
