I am using WFView Ver. 1.5, Icom 7610 and MacBook Air (MacOS High Sierra) and experiencing garbled and broken TX audio. All else (including RX audio) seems to be working fine. Any ides what I am doing wrong? Tried several mics and several “Audio Systems” menu items. No joy.
TX latency is defaulted to 150 ms. Latency and packet loss is not likely. I am on a small LAN (no Internet) and all other features of WFView are working nicely. Rx audio is excellent.
It’s worth trying something. I do use bluetooth headphones with linux sometimes and it seems to work.
You could also try the other audio back ends. But I would probably start with just trying another audio device if you have one available. If that clears it up, then we learn something.
Thanks Elllott. I’ll try a different mic tomorrow. I can make a copy of the TX video file so that you can actually hear what it sounds like. Maybe that will give you a clue.
I got the program working OK! You both had great suggestions and I have deployed your suggestions. I removed the Bluetooth headset and am now using a USB mic or the laptop built-in mic. Thanks guys! Wonderful help!
