– 6may2023,afrt
Addition: It worked for a while but later on, my Ubuntu 24 went haywire. So maybe not do this. Linux audio is a daunting subject.
How to create two or more new virtual loopbacks in linux ALSA, .
that will be created at linux startup/boot. tested on Ubuntu24, with Fldigi, Wfview
- Edit the snd-aloop.service file
sudo nano /etc/systemd/system/snd-aloop.service
- Put the next lines into the file:
__
[Unit]
Description=Creates snd-aloop devices for audio routing
After=multi-user.target
[Service]
Type=simple
User=root
Group=root
ExecStart=/sbin/modprobe snd-aloop enable=1,1 index=10,11
Restart=always
[Install]
WantedBy=multi-user.target
__
Reboot your linux. If all in order you will have 4 stereo channels for audio
(optional:)Check if the new loopbacks are present, look for lines
with: “card 10 (2X) ,card11 (2X)”.#to show a list of devices (cards) , run:
aplay -l -
In Wfview go:
Settings>Radio Access>Audio Output, select : Loopback:PCM (hw:10,0)
-and-
Settings>Radio Access>Audio Input, select : Loopback:PCM (hw:11,0)
- In case Fldigi is used, go:
Configure>Conf dialog>Soundcard>vPortaudio>Capture: “Loopback: PCM (hw:10,1)”
Configure>Conf dialog>Soundcard>vPortaudio>Capture: “Loopback: PCM (hw:11,1)”
n.b. Fldigi can be unforgiving if it can’t find a matching device , no default fold-back. brace yourself.
Now Should be able to connect Fldigi or other app audiowize with WFview, bidirectionally.
- Listening to it by e.g. a loudspeaker. I do not know (yet) , … PulseAudio? sudo modprobe snd_pcm_oss …something .
Maybe doubled with something somewhere else, i looked. Gemini helped considerably
cheers, ko
73 PE1BFE
