Announcement: wfview v2.01 immediately available
prior stored settings, which worked well in 1.64.
it indeed starts well with radio off, after turning on the radio, and pressing connect to radio, it crashes.
Qt Audio is the selected audio system.
After some more tries, I found the problem being the Blackhole virtual audio driver, I’m using to loop audio to and from WSJT-X. Apparently this causes the problem, after selecting the mac speaker and mic, wfview works just fine.
The server is on Debian 12, clients are currently all windows 10. The clients seem to mostly have good RX audio, and really good control and feedback (meters) but no TX audio, and after a period of use (and i suspect adjusting to try fix no TX) RX audio fails.
Some settings are not sticking on the server also - this may be something as simple as permissions. Will dig.
That’s really useful information, thanks. I will install Blackhole on my Mac and do some testing. I suspect it may be related to sample rate, if it has the option, can you try setting Blackhole to 48K. If not it may be possible to adjust in Applications/Utilities/Audio MIDI Setup.
It would also be useful to see the log from a session of wfview that crashed. The easiest way on a Mac is to run wfview with the radio switched off and click the Log button, then click ‘Open Log Directory’ to find all previous logs.
here you are:
2024-12-31 14:21:48.872 INF system: wfview version: 2.01 (Git:7c40060 on Dec 29 2024 at 19:16:02 by phil@Phils-TouchBar.local)
2024-12-31 14:21:48.872 INF system: Operating System: macOS Sequoia (15.1) (arm64)
2024-12-31 14:21:48.872 INF system: Looking for External Dependencies:
2024-12-31 14:21:48.872 INF system: QT Runtime Version: 6.8.1
2024-12-31 14:21:48.872 INF system: OPUS Version: libopus 1.3.1
2024-12-31 14:21:48.872 INF system: HIDAPI Version: 0.13.1
2024-12-31 14:21:48.872 INF system: EIGEN Version: 3.4.0
2024-12-31 14:21:48.872 INF system: QCUSTOMPLOT Version: 2.1.1
2024-12-31 14:21:48.872 INF system: RTAUDIO Version: 6.0.0beta1
2024-12-31 14:21:48.872 INF system: PORTAUDIO Version: PortAudio V19.7.0-devel, revision unknown
2024-12-31 14:21:48.873 INF default: Starting caching queue handler thread (ThreadId: 0x16b813000 )
2024-12-31 14:21:48.904 INF system: Loading settings from  "/Users/gerrit/Library/Containers/org.wfview.wfview/Data/Library/Preferences/org.wfview.wfview.plist"
2024-12-31 14:21:48.930 INF gui: Got Audio Output from Settings:  "BlackHole 2ch"
2024-12-31 14:21:48.930 INF gui: Got Audio Input from Settings:  "BlackHole 2ch"
2024-12-31 14:21:48.932 INF default: Setting color Preset 0 name "Dark"
2024-12-31 14:21:48.934 WRN gui: No UI element matches setting 16
2024-12-31 14:21:48.934 WRN gui: No UI element matches setting 32
2024-12-31 14:21:49.013 INF audio: Audio device(s) found (*=default)
2024-12-31 14:21:49.018 INF audio: * ( 0 ) Input Device :  "BlackHole 2ch"
2024-12-31 14:21:49.018 INF audio:   ( 1 ) Input Device :  "BlackHole 16ch"
2024-12-31 14:21:49.018 INF audio:   ( 2 ) Input Device :  "MacBook Pro Microphone"
2024-12-31 14:21:49.018 INF audio:   ( 3 ) Input Device :  "Gerrit's iPhone Microphone"
2024-12-31 14:21:49.018 INF audio:   ( 4 ) Input Device :  "Microsoft Teams Audio"
2024-12-31 14:21:49.021 INF audio: * ( 0 ) Output Device :  "MacBook Pro Speakers"
2024-12-31 14:21:49.021 INF audio:   ( 1 ) Output Device :  "PHL 273B9"
2024-12-31 14:21:49.021 INF audio:   ( 2 ) Output Device :  "BlackHole 16ch"
2024-12-31 14:21:49.021 INF audio:   ( 3 ) Output Device :  "BlackHole 2ch"
2024-12-31 14:21:49.022 INF audio:   ( 4 ) Output Device :  "Microsoft Teams Audio"
2024-12-31 14:21:49.022 INF default: Looking for inputs
2024-12-31 14:21:49.022 INF default: Looking for outputs
2024-12-31 14:21:49.022 INF audio: "Server Audio input device Microsoft Teams Audio found! "
2024-12-31 14:21:49.022 INF audio: "Server Audio output device Microsoft Teams Audio found! "
2024-12-31 14:21:49.022 INF audio: "Client Audio input device BlackHole 2ch found! "
2024-12-31 14:21:49.022 INF audio: "Client Audio output device BlackHole 2ch found! "
2024-12-31 14:21:49.058 INF default: Changing queue interval to 250 ms
2024-12-31 14:21:49.058 INF rig: creating instance of rigCommander()
2024-12-31 14:21:49.058 INF rig: creating instance of icomCommander()
2024-12-31 14:21:49.058 INF cluster: starting dxClusterClient()
2024-12-31 14:21:49.058 INF udp: Starting udpHandler user: "PA3BYA"  rx latency: 150  tx latency: 150  rx sample rate:  48000  rx codec:  4  tx sample rate:  48000  tx codec:  4
2024-12-31 14:21:49.481 INF udp: Got IP Address : "IC-705.local" :  "192.168.178.54"
2024-12-31 14:21:49.489 INF serial: Opened pt device:  26 , attempting to grant pt status
2024-12-31 14:21:49.489 INF serial: Opened pseudoterminal, slave name : /dev/ttys000
2024-12-31 14:21:49.491 INF serial: Created link to "/dev/ttys000" from "/Users/gerrit/Library/Containers/org.wfview.wfview/Data/Downloads/rig-pty1"
2024-12-31 14:21:49.493 INF udp: UDP Stream bound to local port: 61814  remote port: 50001
2024-12-31 14:21:50.064 INF udp: udpHandler : Received I am here from:  3232281142
2024-12-31 14:21:50.166 INF udp: udpHandler : Received I am ready
2024-12-31 14:21:50.166 INF udp: udpHandler : Sending login packet
2024-12-31 14:21:50.177 INF udp: udpHandler Got new radio time: ( 6846505 ) QTime(01:54:06.505)  Offset: 44863672 Calc time:  QTime(12:27:43.672)
2024-12-31 14:21:50.188 INF udp: Got connection type: "FTTH"
2024-12-31 14:21:50.188 INF udp: udpHandler : Received matching token response to our request
2024-12-31 14:21:50.188 INF udp: udpHandler : Detected connection speed  FTTH
2024-12-31 14:21:50.196 INF udp: udpHandler "Received radio capabilities, Name: IC-705, Audio: ICOM_VAUDIO, CIV: a4, MAC: 00:90:c7:11:14:65 CAPF: 5001"
2024-12-31 14:21:50.196 INF udp: Got Connection status for: IC-705 Busy: 0 Computer  IP "0.0.0.0"
2024-12-31 14:21:50.196 INF udp: Got Radio 0
2024-12-31 14:21:50.196 INF udp: Find available local ports
2024-12-31 14:21:50.197 INF default: Received serial port baud rate from remote server: 19200
2024-12-31 14:21:50.197 INF default: Changing queue interval to 100 ms
2024-12-31 14:21:50.197 INF system: Delay command interval timing:  100 ms
2024-12-31 14:21:50.203 INF udp: Starting udpCivData
2024-12-31 14:21:50.203 INF udp: UDP Stream bound to local port: 57016  remote port: 50002
2024-12-31 14:21:50.203 INF udp: Starting udpAudio
2024-12-31 14:21:50.203 INF udp: UDP Stream bound to local port: 58949  remote port: 50003
2024-12-31 14:21:50.204 INF audio: Input audio handler starting: "BlackHole 2ch"
2024-12-31 14:21:50.204 INF udp: udpHandler Got serial and audio request success, device name:  "IC-705"
2024-12-31 14:21:50.204 INF audio: Output audio handler starting: "BlackHole 2ch"
2024-12-31 14:21:50.204 INF udp: Got Connection status for: IC-705 Busy: 1 Computer  IP "0.0.0.0"
2024-12-31 14:21:50.204 INF audio: Input thread id 0x16bf2f000
2024-12-31 14:21:50.204 INF audio: Output thread id 0x16bea3000
2024-12-31 14:21:50.204 INF audio: Output start() running
2024-12-31 14:21:50.204 INF audioconverter: Starting audioConverter() Input: 1 Channels of 0 48000 Int16 Output: 2 Channels of 0 48000 Float
2024-12-31 14:21:50.204 INF audioconverter: Starting audioConverter() Input: 2 Channels of 0 48000 Float Output: 1 Channels of 0 48000 Int16
2024-12-31 14:21:50.205 INF audio: Input start() running
2024-12-31 14:21:50.209 INF udp: udpCivData : Received I am here
2024-12-31 14:21:50.213 INF udp: udpAudio : Received I am here
2024-12-31 14:21:50.273 INF udp: udpAudio Got new radio time: ( 6846605 ) QTime(01:54:06.605)  Offset: 44863668 Calc time:  QTime(12:27:43.668)
2024-12-31 14:21:50.273 INF udp: udpCivData Got new radio time: ( 6846605 ) QTime(01:54:06.605)  Offset: 44863668 Calc time:  QTime(12:27:43.668)
2024-12-31 14:21:50.427 INF rig: "Have new rig ID: 0xa4"
2024-12-31 14:21:50.428 INF rig: "Loading Rig: IC-705 from /Users/gerrit/Applications/wfview.app/Contents/MacOS/rigs/IC-705.rig"
2024-12-31 14:21:50.429 INF serial: Got rigcaps for: "IC-705"
2024-12-31 14:21:50.429 INF rig: Using incomingCIVAddr: (int):  164  hex:  "0xa4"
2024-12-31 14:21:50.429 INF default: Receiving rigcaps into repeater setup.
2024-12-31 14:21:50.429 INF default: repeaterSetup got rigcaps for: "IC-705"
2024-12-31 14:21:50.430 INF system: Running configureVFOs()
