I think I have this all setup right, I can hear the local repeater and I can PTT the repeater and it kerchunks, but my audio from both OS X and PC Windows does not seem to be getting out.
Any settings I should be looking at?
I have the thing setup over the LAN, the IC-705 is connected to house wifi as are my laptops and I am connecting to the radio via it’s IP address, UN/PW scheme.
Make sure that in the settings tab, Modulation Input is set to LAN (and Data Mod Input if using datamodes) This will change the “Mic” slider to LAN and allow you to change the audio input level.
Is there a web site that shows the ICOM 705 settings for Internet Remote access? I’ve been using RemoteTX for ICOM7300 but have heard wfview is also good.
I’ve got the radio connected to the PC. Display is great and buttons work. But no audio on RX and low on XMIT. I will check out DC4KU report for settings.
Android (and iPhone/iPad) are all supported by the Qt toolkit that wfview uses, so we do plan to support them at some point. There is no timeframe for this support yet though.
