Hi Gordon,
First just a few things to be aware of with wfview and the spectrum controls:
The “Span” control only affects the “Center” spectrum mode. When in center mode, the rig just goes +/- however many KHz is specified. You’ll also notice that as you tune the radio, the spectrum stays centered around your tuned frequency. You probably knew all that already, but just making sure it’s clear.
Under “Fixed” spectrum mode, you can tune around the displayed spectrum. The spectrum stays stationary as you tune, and you have probably noticed you can even tune outside the fixed displayed spectrum. In Fixed mode, the span control doesn’t do anything. The Edge control lets you pick one of four stored spectrum edges. Keep in mind, the Icom radios define four spectrum edges per band, and what Icom calls a band might be different than what you and I consider one. If you tune to 6.999 MHz, you’re now in what is called the “GEN” band (general coverage), and the band edges are now a different set of four compared to if you tune to 7.000 MHz and are in the 40 meter band. Even 60 meters doesn’t have a dedicated spectrum edge set, which is a shame since it would be awfully convenient to have one for this small band!
wfview doesn’t yet have the ability to program in a custom edge. It is something we have thought about though, and I think it would be a good feature to have since I find the radio’s interface for doing this quite cumbersome. The one exception to this, is if you are in the “Center” mode and then you press the “ToFixed” button. This button will override your current selected Edge with whatever is shown on the scope right now, and drop you into Fixed mode. It is a simple way to define a Fixed edge from the Center scope mode. I added this feature because I felt Icom should have it on their rigs, and wouldn’t you know it, we now have “scroll” mode which is sort of similar.
Anyway, if, after reading this, you are still seeing unexpected behavior: Make sure you’re not pressing the “ToFixed” button, and then send us a debug log. This is a special log file you can generate which will contain every little piece of data sent to the radio. When you do this, you’ll want to open wfview, click some buttons as you usually would, experience the bug, and then close wfview. Otherwise the log file will get enormous.
To start wfview with the debug flag, you need to add --debug
to the command-line arguments of wfview. I believe you can do this either via the cmd “dos” prompt, or by making a shortcut to wfview and then editing the properties of the shortcut to specify the command-line arguments. Perhaps a windows user can chime in here if I’ve got it wrong.
After running wfview this way, and experiencing the bug, close wfview, and then issue this command to view the log file (and from there, you can copy-paste to an email). This command is run from a cmd prompt:
notepad %TEMP%\wfview.log
You can read more about the log file and what to expect here:
https://wfview.org/wfview-user-manual/log-file/
Let me know if this helps. I know this issue must be frustrating.
