Running the debian build script I get the following error:
./fullbuild-wfview.sh
./fullbuild-wfview.sh: line 1: syntax error near unexpected token newline' ./fullbuild-wfview.sh: line 1:
HI Paul,
It sounds like the build script was not downloaded properly.
Did you see this video? It shows exactly how I build wfview:
You have to make certain to download the script “raw” and not accidentally download a page of HTML. And don’t forget the chmod command.
Let us know if that helps.
Got a little further then this…wouldn’t get to the point of compiling.
Press Y to install dependencies (Y/n): y
[sudo] password for paul:
Reading package lists… Done
Building dependency tree
Reading state information… Done
build-essential is already the newest version (12.8ubuntu1.1).
0 upgraded, 0 newly installed, 0 to remove and 0 not upgraded.
2 not fully installed or removed.
After this operation, 0 B of additional disk space will be used.
Setting up initramfs-tools (0.136ubuntu6.7) …
update-initramfs: deferring update (trigger activated)
Setting up linux-firmware (1.201.5+system76~1646062142~20.04~b05e0ab~dev) …
update-initramfs: Generating /boot/initrd.img-5.16.11-76051611-generic
cryptsetup: WARNING: nvme0n1p3_crypt: ignoring unknown option ‘nofail’
Error 24 : Write error : cannot write compressed block
E: mkinitramfs failure cpio 141 lz4 -9 -l 24
update-initramfs: failed for /boot/initrd.img-5.16.11-76051611-generic with 1.
dpkg: error processing package linux-firmware (–configure):
installed linux-firmware package post-installation script subprocess returned error exit status 1
Processing triggers for initramfs-tools (0.136ubuntu6.7) …
dpkg: error processing package initramfs-tools (–configure):
installed initramfs-tools package post-installation script subprocess returned error exit status 1
Errors were encountered while processing:
linux-firmware
initramfs-tools
E: Sub-process /usr/bin/dpkg returned an error code (1)
Hi Paul.
That looks to me like you have a problem with your Ubuntu installation as the standard apt package manager is failing, most likely due to limited space in your root partition?
What is the output of the command:
ps ax
paul@SH-Admin:~/Downloads$ ps ax
PID TTY STAT TIME COMMAND
1 ? Ss 0:06 /sbin/init splash
2 ? S 0:00 [kthreadd]
3 ? I< 0:00 [rcu_gp]
4 ? I< 0:00 [rcu_par_gp]
6 ? I< 0:00 [kworker/0:0H-events_highpri]
9 ? I< 0:00 [mm_percpu_wq]
10 ? S 0:00 [rcu_tasks_kthre]
11 ? S 0:00 [rcu_tasks_rude_]
12 ? S 0:00 [rcu_tasks_trace]
13 ? S 1:00 [ksoftirqd/0]
14 ? I 2:06 [rcu_preempt]
15 ? S 0:00 [migration/0]
16 ? S 0:00 [idle_inject/0]
17 ? S 0:00 [cpuhp/0]
18 ? S 0:00 [cpuhp/1]
19 ? S 0:00 [idle_inject/1]
20 ? S 0:00 [migration/1]
21 ? S 0:02 [ksoftirqd/1]
23 ? I< 0:00 [kworker/1:0H-events_highpri]
24 ? S 0:00 [cpuhp/2]
25 ? S 0:00 [idle_inject/2]
26 ? S 0:00 [migration/2]
27 ? S 0:01 [ksoftirqd/2]
29 ? I< 0:00 [kworker/2:0H-kblockd]
30 ? S 0:00 [cpuhp/3]
31 ? S 0:00 [idle_inject/3]
32 ? S 0:00 [migration/3]
33 ? S 0:22 [ksoftirqd/3]
35 ? I< 0:00 [kworker/3:0H-events_highpri]
36 ? S 0:00 [cpuhp/4]
37 ? S 0:00 [idle_inject/4]
38 ? S 0:00 [migration/4]
39 ? S 0:01 [ksoftirqd/4]
41 ? I< 0:00 [kworker/4:0H-events_highpri]
42 ? S 0:00 [cpuhp/5]
43 ? S 0:00 [idle_inject/5]
44 ? S 0:00 [migration/5]
45 ? S 0:05 [ksoftirqd/5]
47 ? I< 0:00 [kworker/5:0H-events_highpri]
48 ? S 0:00 [cpuhp/6]
49 ? S 0:00 [idle_inject/6]
50 ? S 0:00 [migration/6]
51 ? S 1:32 [ksoftirqd/6]
53 ? I< 0:00 [kworker/6:0H-events_highpri]
54 ? S 0:00 [cpuhp/7]
55 ? S 0:00 [idle_inject/7]
56 ? S 0:00 [migration/7]
57 ? S 0:01 [ksoftirqd/7]
59 ? I< 0:00 [kworker/7:0H-kblockd]
60 ? S 0:00 [kdevtmpfs]
61 ? I< 0:00 [netns]
62 ? I< 0:00 [inet_frag_wq]
63 ? S 0:00 [kauditd]
64 ? S 0:00 [khungtaskd]
65 ? S 0:00 [oom_reaper]
66 ? I< 0:00 [writeback]
67 ? S 0:45 [kcompactd0]
68 ? SN 0:00 [ksmd]
69 ? SN 0:01 [khugepaged]
70 ? I< 0:00 [kintegrityd]
71 ? I< 0:00 [kblockd]
72 ? I< 0:00 [blkcg_punt_bio]
73 ? I< 0:00 [tpm_dev_wq]
74 ? I< 0:00 [ata_sff]
75 ? I< 0:00 [md]
76 ? I< 0:00 [edac-poller]
77 ? I< 0:00 [devfreq_wq]
78 ? S 0:00 [watchdogd]
81 ? I< 0:04 [kworker/0:1H-events_highpri]
83 ? S 0:11 [kswapd0]
84 ? S 0:00 [ecryptfs-kthrea]
85 ? I< 0:00 [kthrotld]
89 ? I< 0:00 [acpi_thermal_pm]
93 ? I< 0:00 [vfio-irqfd-clea]
95 ? I< 0:00 [mld]
96 ? I< 0:05 [kworker/6:1H-events_highpri]
97 ? I< 0:00 [ipv6_addrconf]
110 ? I< 0:00 [kstrp]
116 ? I< 0:00 [zswap-shrink]
165 ? I< 0:00 [charger_manager]
187 ? I< 0:04 [kworker/3:1H-kblockd]
222 ? I< 0:06 [kworker/4:1H-events_highpri]
224 ? I< 0:00 [nvme-wq]
225 ? I< 0:00 [nvme-reset-wq]
226 ? I< 0:00 [cryptd]
227 ? I< 0:00 [nvme-delete-wq]
228 ? S 1:17 [irq/51-ELAN040D]
252 ? I< 0:03 [kworker/5:1H-events_highpri]
253 ? I< 0:02 [kworker/1:1H-events_highpri]
256 ? S 0:00 [card0-crtc0]
257 ? S 0:00 [card0-crtc1]
258 ? S 0:00 [card0-crtc2]
318 ? I< 0:03 [kworker/7:1H-events_highpri]
319 ? I< 0:07 [kworker/2:1H-events_highpri]
328 ? I< 0:00 [kdmflush/253:0]
333 ? I< 0:00 [kcryptd_io/253:]
334 ? I< 0:00 [kcryptd/253:0]
335 ? S 0:08 [dmcrypt_write/2]
344 ? I< 0:00 [kdmflush/253:1]
345 ? I< 0:00 [kdmflush/253:2]
395 ? S 0:10 [jbd2/dm-1-8]
396 ? I< 0:00 [ext4-rsv-conver]
450 ? S<s 0:20 /lib/systemd/systemd-journald
503 ? Ss 0:00 /lib/systemd/systemd-udevd
571 ? I< 0:00 [cfg80211]
585 ? S 1:00 [irq/146-iwlwifi]
586 ? S 0:10 [irq/147-iwlwifi]
587 ? S 0:14 [irq/148-iwlwifi]
588 ? S 0:11 [irq/149-iwlwifi]
589 ? S 0:19 [irq/150-iwlwifi]
590 ? S 0:31 [irq/151-iwlwifi]
591 ? S 0:22 [irq/152-iwlwifi]
592 ? S 0:25 [irq/153-iwlwifi]
593 ? S 0:16 [irq/154-iwlwifi]
594 ? S 0:00 [irq/155-iwlwifi]
692 ? S 0:00 [jbd2/nvme0n1p2-]
693 ? I< 0:00 [ext4-rsv-conver]
813 ? Ss 0:17 /lib/systemd/systemd-resolved
824 ? Ssl 0:00 /lib/systemd/systemd-timesyncd
932 ? Ssl 0:03 /usr/lib/accountsservice/accounts-daemon
933 ? Ss 0:01 /usr/sbin/acpid
935 ? Ss 0:10 avahi-daemon: running [SH-Admin.local]
936 ? Ss 0:00 /usr/lib/bluetooth/bluetoothd
937 ? Ss 0:00 /usr/sbin/cron -f
940 ? Ss 1:03 /usr/bin/dbus-daemon --system --address=systemd: –
947 ? Ssl 0:08 /usr/sbin/irqbalance --foreground
956 ? Ss 0:00 /usr/bin/python3 /usr/bin/networkd-dispatcher --run
962 ? Ssl 0:01 /usr/lib/policykit-1/polkitd --no-debug
967 ? Ssl 0:08 /usr/sbin/rsyslogd -n -iNONE
969 ? Ss 0:00 /usr/sbin/smartd -n
974 ? Ssl 0:00 /usr/libexec/switcheroo-control
976 ? Ss 0:00 /usr/bin/python3 /usr/lib/system76-driver/system76-
977 ? Ss 0:04 /usr/lib/system76-firmware/system76-firmware-daemon
978 ? Ss 0:48 /usr/bin/system76-power daemon
979 ? Ss 0:00 /lib/systemd/systemd-logind
983 ? Ssl 0:02 /usr/lib/udisks2/udisksd
984 ? Ss 0:20 /sbin/wpa_supplicant -u -s -O /run/wpa_supplicant
988 ? Ss 0:00 /usr/sbin/atd -f
1007 ? S 0:00 avahi-daemon: chroot helper
1054 ? Ssl 0:00 /usr/libexec/colord
1062 ? Ssl 0:02 /usr/bin/syncthing serve --no-browser --no-restart
1090 ? Ssl 0:00 /usr/sbin/lightdm
1137 ? SNl 12:12 /usr/bin/syncthing serve --no-browser --no-restart
1158 ? Ss 0:00 /lib/systemd/systemd --user
1159 ? S 0:00 (sd-pam)
1176 tty7 Rsl+ 69:27 /usr/lib/xorg/Xorg -core :0 -seat seat0 -auth /var/
1178 ? Ssl 98:11 /usr/bin/pulseaudio --daemonize=no --log-target=jou
1181 tty1 Ss+ 0:00 /sbin/agetty -o -p – \u --noclear tty1 linux
1183 ? SNsl 0:01 /usr/libexec/rtkit-daemon
1193 ? Ss 0:12 /usr/bin/dbus-daemon --session --address=systemd: -
1196 ? S< 0:00 [krfcommd]
1197 ? Ssl 0:04 /usr/lib/upower/upowerd
1229 ? Sl 0:00 lightdm --session-child 12 15
1234 ? Ssl 0:02 cinnamon-session --session cinnamon
1310 ? Ss 0:00 /usr/bin/ssh-agent /usr/bin/im-launch cinnamon-sess
1323 ? Ssl 0:00 /usr/libexec/gvfsd
1328 ? Sl 0:00 /usr/libexec/gvfsd-fuse /run/user/1000/gvfs -f -o b
1334 ? Ssl 0:00 /usr/libexec/at-spi-bus-launcher
1340 ? S 1:06 /usr/bin/dbus-daemon --config-file=/usr/share/defau
1343 ? Sl 0:10 /usr/libexec/at-spi2-registryd --use-gnome-session
1350 ? SLl 0:00 /usr/bin/gnome-keyring-daemon --start --components=
1358 ? Sl 0:00 csd-color
1361 ? Sl 0:00 csd-clipboard
1363 ? Sl 0:00 csd-mouse
1364 ? Sl 0:02 csd-media-keys
1365 ? Sl 0:02 csd-sound
1366 ? Sl 0:10 csd-keyboard
1368 ? Sl 0:00 csd-automount
1373 ? Sl 0:00 csd-a11y-keyboard
1374 ? Sl 0:03 csd-power
1375 ? Sl 0:00 csd-cursor
1376 ? Sl 0:00 csd-a11y-settings
1380 ? Sl 0:00 csd-background
1381 ? Sl 0:00 csd-orientation
1382 ? Sl 0:01 csd-screensaver-proxy
1389 ? Sl 0:00 csd-xsettings
1397 ? Sl 0:00 csd-xrandr
1399 ? Sl 0:00 csd-wacom
1403 ? Sl 0:05 csd-housekeeping
1404 ? Sl 0:00 csd-print-notifications
1417 ? Ssl 0:00 /usr/libexec/gvfs-udisks2-volume-monitor
1423 ? Ssl 0:00 /usr/libexec/gvfs-gphoto2-volume-monitor
1459 ? Sl 0:00 /usr/libexec/dconf-service
1460 ? Ssl 0:00 /usr/libexec/gvfs-goa-volume-monitor
1470 ? Sl 0:00 /usr/libexec/goa-daemon
1490 ? Sl 0:00 /usr/libexec/goa-identity-service
1496 ? Sl 0:00 /usr/libexec/csd-printer
1499 ? Ssl 0:02 /usr/libexec/gvfs-afc-volume-monitor
1506 ? Ssl 0:00 /usr/libexec/gvfs-mtp-volume-monitor
1515 ? Sl 0:12 cinnamon-launcher
1521 ? Rl 71:12 cinnamon --replace
1540 ? Sl 0:17 /usr/libexec/xapps/sn-watcher/xapp-sn-watcher
1549 ? Sl 2:00 /usr/lib/caribou/caribou
1553 ? S 0:00 bwrap --args 33 discord
1554 ? Sl 0:01 /usr/lib/policykit-1-gnome/polkit-gnome-authenticat
1560 ? Sl 0:02 /usr/lib/protonmail/bridge/proton-bridge-launcher -
1562 ? Sl 0:00 /usr/libexec/geoclue-2.0/demos/agent
1567 ? Sl 0:00 /usr/libexec/evolution-data-server/evolution-alarm-
1581 ? Sl 0:00 blueberry-obex-agent
1589 ? Ssl 0:00 /usr/libexec/flatpak-session-helper
1590 ? S 0:00 /usr/bin/python3 /usr/lib/system76-driver/system76-
1594 ? Sl 0:21 nemo-desktop
1597 ? Sl 0:38 nm-applet
1598 ? Ss 0:00 server --sh -n /run/user/1000/.flatpak-helper/pkcs1
1605 ? Ssl 0:00 /usr/libexec/xdg-document-portal
1606 ? Sl 0:00 cinnamon-killer-daemon
1618 ? Ssl 0:00 /usr/libexec/evolution-source-registry
1620 ? Ssl 0:00 /usr/libexec/xdg-permission-store
1646 ? S 0:00 bwrap --args 33 xdg-dbus-proxy --args=36
1647 ? Sl 0:00 xdg-dbus-proxy --args=36
1650 ? S 0:00 bwrap --args 33 discord
1661 ? Ss 0:00 /usr/lib/bluetooth/obexd
1664 ? S 0:00 /bin/bash /app/bin/discord
1668 ? Ssl 0:00 /usr/libexec/evolution-calendar-factory
1671 ? S 0:00 socat UNIX-LISTEN:/run/user/1000/app/com.discordapp
1685 ? Ssl 0:00 /usr/libexec/evolution-addressbook-factory
1719 ? Sl 9:50 /app/discord/Discord
1725 ? S 0:00 cat
1726 ? S 0:00 cat
1892 ? S 0:00 /app/discord/Discord --type=zygote --no-zygote-sand
1893 ? S 0:00 /app/discord/chrome-sandbox /app/discord/Discord –
1923 ? SLl 7:48 /home/paul/.cache/protonmail/bridge/updates/2.1.1/p
2113 ? Sl 28:35 /app/discord/Discord --type=gpu-process --field-tri
2125 ? Sl 0:09 /app/discord/Discord --type=utility --utility-sub-t
2151 ? I< 0:00 [kdmflush/253:3]
2152 ? I< 0:00 [kcryptd_io/253:]
2153 ? I< 0:00 [kcryptd/253:3]
2154 ? S 0:00 [dmcrypt_write/2]
2194 ? S 0:00 [jbd2/dm-3-8]
2197 ? I< 0:00 [ext4-rsv-conver]
2210 ? Ssl 0:00 /usr/libexec/xdg-desktop-portal
2214 ? Ssl 0:00 /usr/libexec/xdg-desktop-portal-gtk
2224 ? S 0:00 p11-kit-remote --provider p11-kit-trust.so pkcs11:m
2226 ? S 0:00 sh -c /usr/lib/x86_64-linux-gnu/libproxy/0.4.15/pxg
2227 ? Sl 0:00 /usr/lib/x86_64-linux-gnu/libproxy/0.4.15/pxgsettin
2234 ? Sl 0:00 /usr/libexec/gvfsd-trash --spawner :1.7 /org/gtk/gv
2243 ? Ssl 0:01 /usr/libexec/gvfsd-metadata
2246 ? S 0:00 bwrap --args 28 nextcloud
2268 ? Ss 0:00 /usr/sbin/kerneloops --test
2285 ? Ss 0:00 /usr/sbin/kerneloops
2311 ? S 0:00 bwrap --args 30 xdg-dbus-proxy --args=32
2315 ? Sl 0:04 xdg-dbus-proxy --args=32
2323 ? I< 0:00 [iprt-VBoxWQueue]
2333 ? S 0:00 bwrap --args 28 nextcloud
2351 ? S 0:00 [iprt-VBoxTscThr]
2358 ? SLl 4:15 nextcloud
2401 ? Sl 76:12 /app/discord/Discord --type=renderer --autoplay-pol
2426 ? Sl 0:00 blueberry-tray
2434 ? S 0:00 /usr/bin/python3 /usr/lib/blueberry/safechild /usr/
2435 ? S 0:00 /usr/sbin/rfkill event
2451 ? Sl 0:01 /app/discord/Discord --type=utility --utility-sub-t
2497 ? Sl 0:12 mintUpdate
2562 ? S 0:06 /usr/bin/python3 /usr/share/system-config-printer/a
2575 ? Sl 0:00 mintreport-tray
7034 ? Sl 0:00 /usr/libexec/gvfsd-http --spawner :1.7 /org/gtk/gvf
7427 ? S 0:00 dbus-launch --autolaunch=aaa642a1efb049fba8d6ca0c8d
7428 ? Ss 0:00 /usr/bin/dbus-daemon --syslog-only --fork --print-p
9924 ? Sl 0:00 /usr/libexec/gvfsd-network --spawner :1.7 /org/gtk/
9941 ? Sl 0:00 /usr/libexec/gvfsd-dnssd --spawner :1.7 /org/gtk/gv
10000 ? S 0:00 bwrap --args 31 zoom 10009 ? S 0:00 bwrap --args 31 xdg-dbus-proxy --args=34 10010 ? Sl 0:00 xdg-dbus-proxy --args=34 10012 ? S 0:00 bwrap --args 31 zoom 10016 ? S 0:00 /app/extra/zoom/ZoomLauncher 10017 ? SLl 204:01 /app/extra/zoom/zoom 12445 ? Ss 0:00 /usr/sbin/cupsd -l 12446 ? Ssl 0:00 /usr/sbin/cups-browsed 125098 ? Ssl 0:00 /usr/sbin/ModemManager 125589 ? Ss 0:00 sshd: /usr/sbin/sshd -D [listener] 0 of 10-100 star 125745 ? Ssl 0:35 /usr/sbin/NetworkManager --no-daemon 170379 ? Sl 62:13 /usr/lib/firefox/firefox 170448 ? Sl 0:02 /usr/lib/firefox/firefox-bin -contentproc -parentBu 170479 ? Sl 0:16 /usr/lib/firefox/firefox-bin -contentproc -childID 170511 ? Ssl 0:00 /usr/sbin/pcscd --foreground --auto-exit 170550 ? Sl 6:38 /usr/lib/firefox/firefox-bin -contentproc -childID 170628 ? Sl 6:47 /usr/lib/firefox/firefox-bin -contentproc -childID 170633 ? Sl 15:15 /usr/lib/firefox/firefox-bin -contentproc -childID 170746 ? Sl 0:11 /usr/lib/firefox/firefox-bin -contentproc -childID 170882 ? Sl 0:01 vncviewer 170884 ? S 0:00 sh -c /usr/lib/x86_64-linux-gnu/libproxy/0.4.15/pxg 170885 ? Sl 0:00 /usr/lib/x86_64-linux-gnu/libproxy/0.4.15/pxgsettin 172542 ? Rsl 1:25 /usr/libexec/gnome-terminal-server 172550 pts/0 Ss 0:00 bash 172697 ? Sl 0:02 /usr/lib/speech-dispatcher-modules/sd_generic /etc/ 172702 ? Sl 0:02 /usr/lib/speech-dispatcher-modules/sd_espeak-ng /et 172708 ? Sl 0:02 /usr/lib/speech-dispatcher-modules/sd_dummy /etc/sp 172711 ? Ssl 0:00 /usr/bin/speech-dispatcher --spawn --communication- 173569 ? Sl 10:56 /usr/lib/firefox/firefox-bin -contentproc -parentBu 173902 ? Sl 5:34 /usr/lib/firefox/firefox-bin -contentproc -childID 174884 ? Sl 0:01 /usr/lib/firefox/firefox-bin -contentproc -childID 178824 ? I< 0:00 [uas] 182788 ? Sl 0:04 /usr/lib/firefox/firefox-bin -contentproc -childID 183759 ? Sl 0:51 /usr/lib/firefox/firefox-bin -contentproc -childID 184440 ? Sl 0:21 /usr/lib/firefox/firefox-bin -contentproc -childID 184531 ? Sl 2:31 /usr/lib/firefox/firefox-bin -contentproc -childID 184781 ? Sl 0:37 /usr/lib/firefox/firefox-bin -contentproc -childID 188418 ? I 0:02 [kworker/u16:8-events_unbound] 189235 ? Sl 0:32 /usr/lib/firefox/firefox-bin -contentproc -childID 189553 ? Sl 8:22 /usr/lib/thunderbird/thunderbird 189639 ? Sl 0:00 /usr/lib/thunderbird/thunderbird -contentproc -chil 189663 ? Sl 0:00 /usr/lib/thunderbird/thunderbird -contentproc -chil 189770 ? I 0:01 [kworker/u16:4-kcryptd/253:0] 190363 ? I 0:01 [kworker/u16:6-kcryptd/253:0] 190504 ? Ssl 0:01 /usr/libexec/fwupd/fwupd 190712 ? I 0:00 [kworker/u16:0-kcryptd/253:0] 191583 ? Sl 0:13 /usr/lib/firefox/firefox-bin -contentproc -childID 191757 ? Sl 0:01 nemo 191814 ? I 0:00 [kworker/u16:9-events_unbound] 191897 ? I< 0:02 [kworker/u17:0-rb_allocator] 192033 ? Sl 2:50 /usr/lib/firefox/firefox-bin -contentproc -childID 192176 ? I 0:00 [kworker/u16:10-kcryptd/253:0] 192299 ? I 0:00 [kworker/u16:1-kcryptd/253:0] 192374 ? Sl 0:03 /usr/lib/firefox/firefox-bin -contentproc -childID 204488 ? I 0:00 [kworker/u16:7-kcryptd/253:0] 216426 ? I 0:02 [kworker/6:0-events] 216500 ? I 0:00 [kworker/7:0-events] 216599 ? I 0:00 [kworker/2:0-events] 216604 ? I 0:00 [kworker/1:1-mm_percpu_wq] 216627 ? I< 0:01 [kworker/u17:1-rb_allocator] 216628 ? Sl 0:07 /usr/bin/vncviewer -child 7300PI 0 216629 ? S 0:00 sh -c /usr/lib/x86_64-linux-gnu/libproxy/0.4.15/pxg 216630 ? Sl 0:00 /usr/lib/x86_64-linux-gnu/libproxy/0.4.15/pxgsettin 216665 ? I 0:00 [kworker/4:2-events] 216681 ? I 0:00 [kworker/3:2-events] 216683 ? Sl 0:01 /usr/bin/vncviewer -child SH-ROTATORPC 0 216684 ? S 0:00 sh -c /usr/lib/x86_64-linux-gnu/libproxy/0.4.15/pxg 216685 ? Sl 0:00 /usr/lib/x86_64-linux-gnu/libproxy/0.4.15/pxgsettin 216798 ? Sl 0:03 /usr/lib/firefox/firefox-bin -contentproc -childID 216861 ? Sl 0:00 /usr/lib/firefox/firefox-bin -contentproc -childID 216963 ? Sl 0:21 /usr/lib/firefox/firefox-bin -contentproc -childID 217086 ? I 0:00 [kworker/5:1-mm_percpu_wq] 217381 ? I 0:00 [kworker/6:2-events] 217479 ? I 0:00 [kworker/0:1-events] 217524 ? Sl 0:00 /usr/lib/firefox/firefox-bin -contentproc -childID 217596 ? Sl 0:12 /usr/lib/firefox/firefox-bin -contentproc -childID 217639 ? Sl 0:03 /usr/lib/firefox/firefox-bin -contentproc -childID 217688 ? Sl 0:01 /usr/lib/firefox/firefox-bin -contentproc -childID 217747 ? Sl 0:01 /usr/lib/firefox/firefox-bin -contentproc -childID 217750 ? Sl 0:00 /usr/lib/firefox/firefox-bin -contentproc -childID 217869 ? Sl 0:07 /usr/lib/firefox/firefox-bin -contentproc -childID 217872 ? Sl 0:00 /usr/lib/firefox/firefox-bin -contentproc -childID 217956 ? I 0:00 [kworker/4:1-events] 217975 ? Sl 0:25 /usr/lib/firefox/firefox-bin -contentproc -childID 218031 ? Sl 0:06 /usr/lib/firefox/firefox-bin -contentproc -childID 218140 ? I 0:00 [kworker/3:1-events] 218201 ? I 0:00 [kworker/u16:3-kcryptd/253:0] 218207 ? I 0:00 [kworker/5:2-mm_percpu_wq] 218208 ? I 0:00 [kworker/2:2-events] 218210 ? I 0:00 [kworker/7:1-events] 218213 ? I 0:00 [kworker/1:0-events] 218220 ? I 0:00 [kworker/0:0-events] 218221 ? I 0:00 [kworker/4:0-mm_percpu_wq] 218229 ? I 0:00 [kworker/3:0-events] 218238 ? D< 0:00 [kworker/u17:2+i915_flip] 218279 ? Sl 0:00 /usr/lib/firefox/firefox-bin -contentproc -childID 218341 ? Sl 0:00 /usr/lib/firefox/firefox-bin -contentproc -childID 218364 ? I 0:00 [kworker/5:0-events] 218386 ? Sl 0:00 /usr/lib/firefox/firefox-bin -contentproc -childID 218415 ? I 0:00 [kworker/2:1-mm_percpu_wq] 218419 ? I 0:00 [kworker/6:1-mm_percpu_wq] 218420 ? I 0:00 [kworker/7:2-mm_percpu_wq] 218429 ? I 0:00 [kworker/0:2] 218430 pts/0 R+ 0:00 ps ax
Hi Paul,
Is your disk full? Are you running an encrypted disk setup?
We’re definitely seeing some errors here with apt, as Phil pointed out. When you tried to install the first dependency, your apt went after some prior incomplete work, updating your initramfs (part of your boot process). This is not good, you have to work this out first so that you can at least use apt. As it stands, I would not even reboot until you have that fixed up.
It looks like you might have a System 76 product, so you might want to ask them to help you get apt-get commands to work properly. The first two apt-get commands in the script are:
sudo apt-get -y install build-essential || exit -1
sudo apt-get -y install qt5-qmake || exit -1
And I suspect the first one is failing.
Not full, but yes, encrypted disk.
Definitely contact System 76, tell them your package system is broken due to some kind of failing firmware or encryption-related error.
So I had a linux guru friend of mine log in. You were correct, the disk was full. For some reason autoremove wasn’t working for the longest time and I wondered about that. I had 5% disk space on root left and apt wasn’t happy about that. As to why I’m not getting warnings about disk space, that’s another issue. Sorry to direct the error at your script…its my wonderful machine’s fault, and partial operator error on my part.
Your project looks amazing by the way. I just bought an IC-7610 and hope to get your program working with it soon. Hopefully you can provide support for the RC-28 as well. Do you have a donation process set up?
Hi Paul,
I’m glad you found the issue! It’s frightening when core components like the boot image or the package manager are malfunctioning.
I was going to let Phil respond to your question about the RC-28, but the overall answer is, he has made it work and he’s just got a lot of irons in the fire right now. To support that controller, besides just the basic code to interpret it, we have to have a user interface to select the controller and preferences to save the settings. So there’s a bit of gluing to do.
And yes, we have a donation system set up under Patreon:
As a member, you receive some behind-the-scenes information and fresh windows and linux builds every evening. Membership starts at $2/month, and we have 16 supporters right now.
Let me know if you get it compiled. And yes, we do support the IC-7610, it’s a very nice radio to use over the built-in ethernet.
Yes, I got it compiled after the /boot was fixed. I just have to keep an eye on it and make sure it still can remove old kernels.
The only hiccup with the build was no icon was put in applications. Have to run “wfview” from the terminal.
Hi Paul,
Do you see wfview’s application launcher in this directory:
/usr/share/applications/
You should see it, it is named “wfview.desktop”.
If you do, you might just need to log out and log back in. We didn’t include the “update the menu” command in our build script, although I could see adding that in the future. Anyway, if it is there, you can just copy it to your desktop, for example.
Hi Elliott,
Yes a log off/log on will show the entry. In my case under “internet” applications (Linux Mint)
73,
Peter - PA0PJE
Cool. There is some command that causes the menu to refresh as well, but I can’t remember what it is. We could add that to the build script.
Hi Elliott,
Might this be the command you’re looking for?
xdg-desktop-menu
xdg-desktop-menu - command line tool for (un)installing desktop menu items
Synopsis
xdg-desktop-menu install [–noupdate] [–novendor] [–mode mode] directory-file(s) desktop-file(s)
xdg-desktop-menu uninstall [–noupdate] [–mode mode] directory-file(s) desktop-file(s)
xdg-desktop-menu forceupdate [–mode mode]
xdg-desktop-menu { --help | --manual | --version }
Use ‘man xdg-desktop-menu’ or ‘xdg-desktop-menu --manual’ for additional info.
73,
Peter
