Hi
ill can not build it with the script: fullbuild-wfview.sh · master · Elliott Liggett / scripts · GitLab
Im on a raspberry pi and the latest Raspbian.
Get this output: https://termbin.com/eypw
73s de SA5LKC
Hi
73s de SA5LKC
What model/specification Pi are you using? That looks like memory exhaustion, which we have seen with older model Pis with less memory. You can try editing the line in the script:
time make -j2 2>&1 | tee -a /tmp/build.log
Remove “-j2” (this tells make to run two simultaneous compile threads.
If using an older or 2GB Pi, you will likely find that wfview doesn’t run very well though!
Hi tnx. Thats a Rpi zero 2W. Had seen that other install via this script. Gonna try to remove that in the script and try again.
// Jocke.
It will be interesting to see if that works, the Zero 2W has only 512 MB RAM IIRC, that may prove to be difficult to run wfview on!
