WSJT-X works fine usingHamlib NET rigctl 127.0.0.1:4533
I have created a virtual serial port pair 11/12. I chose Virtual Serial Port 11 in WFView, and I am selecting Virtual Serial Port 12 in Bandmaster but it keeps saying the radio is not responding.
I have tried all possible baud rates without success. I remember I had this working over the weekend but I have made so many changes and my memory is foggy. Any help would be appreciated.
I’m not able to get the virtual serial port to work for rig control to an IC-9700 from WSJT-X, even if I disable rigctld. I use com0com for virtual serial port connectivity, and it works fine with my Anan-100D to WSJT-X. So I gave up and am just using rigctld and that works fine for me with the 9700.
I have to modify my earlier statement. I’ve finally gotten to where I can control the rig via a virtual serial port from WSJT-X to Wfview. And this is working even though I also have the rigctld enabled at the same time, so I can switch back and forth in the WSJT-X configuration. The “magic” was the usual Windows technique of kicking things until they work, in particular I ended up using the setup program for the com0com virtual serial ports to reset their configuration.
