If I Power down radio (Icom 7300) then Power up the Server running Wfview the Radio will not power up from remote client.
Running 1.64 with nightly build on Windows remote and 1.61 on an Invato Quadra server.
Remote log:
2023-08-03 12:40:45.638 INF system: “wfview version: 1.63 (Git:54b00b9 on Jul 12 2023 at 03:02:06 by build@wfview.org). Operating System: Windows 11 Version 2009 (x86_64). Build Qt Version 6.3.2. Current Qt Version: 6.3.2”
2023-08-03 12:40:45.654 INF system: Loading settings from “\HKEY_CURRENT_USER\Software\wfview\wfview”
2023-08-03 12:40:45.681 INF rigctld: started on port 4533
2023-08-03 12:40:45.682 INF gui: Got Audio Output from Settings: “CABLE Input (VB-Audio Virtual Cable)”
2023-08-03 12:40:45.682 INF gui: Got Audio Input from Settings: “CABLE Output (VB-Audio Virtual Cable)”
2023-08-03 12:40:45.703 INF cw: “Sidetone Output: 1 - LG TV SSCR2 (AMD High Definition Audio Device) (volume: 0 rate: 44100 type: 2”
2023-08-03 12:40:45.703 INF audio: Audio device(s) found (*=default)
2023-08-03 12:40:45.704 INF audio: * ( 0 ) Input Device : “CABLE Output (VB-Audio Virtual Cable)”
2023-08-03 12:40:45.704 INF audio: ( 1 ) Input Device : “Microphone (HD Pro Webcam C920)”
2023-08-03 12:40:45.706 INF audio: * ( 0 ) Output Device : “1 - LG TV SSCR2 (AMD High Definition Audio Device)”
2023-08-03 12:40:45.706 INF audio: ( 1 ) Output Device : “CABLE Input (VB-Audio Virtual Cable)”
2023-08-03 12:40:45.706 INF default: Looking for inputs
2023-08-03 12:40:45.707 INF audio: "Client Audio input device CABLE Output (VB-Audio Virtual Cable) found! "
2023-08-03 12:40:45.707 INF default: Looking for outputs
2023-08-03 12:40:45.707 INF audio: "Client Audio output device CABLE Input (VB-Audio Virtual Cable) found! "
2023-08-03 12:40:45.708 INF audio: "Server Audio input device Microphone (HD Pro Webcam C920) found! "
2023-08-03 12:40:45.708 INF audio: "Server Audio output device 1 - LG TV SSCR2 (AMD High Definition Audio Device) found! "
2023-08-03 12:40:45.910 INF system: Cannot prepare WF view without rigCaps. Waiting on this.
2023-08-03 12:40:45.914 INF rig: creating instance of rigCommander()
2023-08-03 12:40:45.915 INF cluster: starting dxClusterClient()
2023-08-03 12:40:45.915 INF udp: Starting udpHandler user: “Ken” rx latency: 150 tx latency: 150 rx sample rate: 48000 rx codec: 64 tx sample rate: 48000 tx codec: 64
2023-08-03 12:40:45.917 INF udp: UDP Stream bound to local port: 63691 remote port: 50004
2023-08-03 12:40:45.983 INF system: Received CommReady!!
2023-08-03 12:40:45.983 INF default: Setting rig state for wfmain
2023-08-03 12:40:46.420 INF udp: udpHandler : Received I am here from: QHostAddress(“::ffff:24.141.36.99”)
2023-08-03 12:40:46.423 INF udp: udpHandler : Received I am ready
2023-08-03 12:40:46.423 INF udp: udpHandler : Sending login packet
2023-08-03 12:40:46.424 INF udp: Got connection type: “WFVIEW”
2023-08-03 12:40:46.424 INF udp: udpHandler : Received matching token response to our request
2023-08-03 12:40:46.424 INF udp: udpHandler : Detected connection speed WFVIEW
2023-08-03 12:40:46.427 INF udp: udpHandler “Received radio capabilities, Name: , Audio: ICOM_VAUDIO, CIV: 00, MAC: 00:90:c7:36:43:3a CAPF: 5001”
2023-08-03 12:40:46.427 INF udp: Got Connection status for: Busy: 2 Computer IP “0.0.0.0”
