- Operating System: Win 11 64 bit
- Method of download attempted (from wfview.org, package manager, source code, etc): wfview.org
- Radio Model: new 7610
- Method of radio connectivity (USB, WiFi, Ethernet, etc): ethernet
- Did you check the FAQ and read the manual? Yes, and the message boards
Sorry, this has been asked before but I can’t seem to get mine working.
NTP is activated and working
WFView 1.64
Radio access via LAN
CI-V transceive is ON for the rig and is NOT selected in WFView.
When I select “Connect to radio” I don’t see any indication of a connection, but I don’t get an error. It says briefly “searching CI-V bus for connected radios” and then nothing.
Log output:
2024-04-29 22:51:45.114 INF system: “wfview version: 1.64 (Git:b4c079f on Jul 16 2023 at 14:29:30 by build@wfview.org). Operating System: Windows 10 Version 22H2 (x86_64). Build Qt Version 6.5.1. Current Qt Version: 6.5.1”
2024-04-29 22:51:45.159 INF system: Loading settings from “C:/Users/wd4el/AppData/Roaming/wfview/wfview/IC-7610.conf”
2024-04-29 22:51:45.215 INF gui: Got Audio Output from Settings: “Speakers (6- USB Audio CODEC )”
2024-04-29 22:51:45.215 INF gui: Got Audio Input from Settings: “Microphone (6- USB Audio CODEC )”
2024-04-29 22:51:45.320 INF cw: “Sidetone Output: Speakers (Realtek(R) Audio) (volume: 0 rate: 44100 type: 2”
2024-04-29 22:51:45.321 INF audio: Audio device(s) found (*=default)
2024-04-29 22:51:45.333 INF audio: * ( 0 ) Input Device : “Stereo Mix (Realtek(R) Audio)”
2024-04-29 22:51:45.333 INF audio: ( 1 ) Input Device : “Line 4 (Virtual Audio Cable)”
2024-04-29 22:51:45.333 INF audio: ( 2 ) Input Device : “Microphone (6- USB Audio CODEC )”
2024-04-29 22:51:45.333 INF audio: ( 3 ) Input Device : “Line (USB AUDIO CODEC)”
2024-04-29 22:51:45.333 INF audio: ( 4 ) Input Device : “Line 2 (Virtual Audio Cable)”
2024-04-29 22:51:45.333 INF audio: ( 5 ) Input Device : “Line 6 (Virtual Audio Cable)”
2024-04-29 22:51:45.333 INF audio: ( 6 ) Input Device : “CABLE-B Output (VB-Audio Cable B)”
2024-04-29 22:51:45.334 INF audio: ( 7 ) Input Device : “Line 3 (Virtual Audio Cable)”
2024-04-29 22:51:45.334 INF audio: ( 8 ) Input Device : “Line 1 (Virtual Audio Cable)”
2024-04-29 22:51:45.334 INF audio: ( 9 ) Input Device : “CABLE-B Output (VB-Audio Virtual Cable)”
2024-04-29 22:51:45.334 INF audio: ( 10 ) Input Device : “Microphone (5- USB Audio CODEC )”
2024-04-29 22:51:45.334 INF audio: ( 11 ) Input Device : “CABLE-A Output (VB-Audio Cable A)”
2024-04-29 22:51:45.334 INF audio: ( 12 ) Input Device : “Line 5 (Virtual Audio Cable)”
2024-04-29 22:51:45.353 INF audio: * ( 0 ) Output Device : “Speakers (Realtek(R) Audio)”
2024-04-29 22:51:45.353 INF audio: ( 1 ) Output Device : “Speakers (VB-Audio Cable A)”
2024-04-29 22:51:45.354 INF audio: ( 2 ) Output Device : “ASUS VS247 (NVIDIA High Definition Audio)”
2024-04-29 22:51:45.354 INF audio: ( 3 ) Output Device : “Line 2 (Virtual Audio Cable)”
2024-04-29 22:51:45.354 INF audio: ( 4 ) Output Device : “Speakers (6- USB Audio CODEC )”
2024-04-29 22:51:45.354 INF audio: ( 5 ) Output Device : “Realtek Digital Output (Realtek(R) Audio)”
2024-04-29 22:51:45.354 INF audio: ( 6 ) Output Device : “Line 1 (Virtual Audio Cable)”
2024-04-29 22:51:45.354 INF audio: ( 7 ) Output Device : “Speakers (VB-Audio Cable B)”
2024-04-29 22:51:45.354 INF audio: ( 8 ) Output Device : “Speakers (USB AUDIO CODEC)”
2024-04-29 22:51:45.354 INF audio: ( 9 ) Output Device : “Speakers (5- USB Audio CODEC )”
2024-04-29 22:51:45.354 INF audio: ( 10 ) Output Device : “Line 3 (Virtual Audio Cable)”
2024-04-29 22:51:45.354 INF audio: ( 11 ) Output Device : “ASUS VS247 (NVIDIA High Definition Audio)”
2024-04-29 22:51:45.354 INF audio: ( 12 ) Output Device : “VS248 (NVIDIA High Definition Audio)”
2024-04-29 22:51:45.355 INF audio: ( 13 ) Output Device : “Line 5 (Virtual Audio Cable)”
2024-04-29 22:51:45.355 INF audio: ( 14 ) Output Device : “CABLE-B Input (VB-Audio Virtual Cable)”
2024-04-29 22:51:45.355 INF audio: ( 15 ) Output Device : “Line 4 (Virtual Audio Cable)”
2024-04-29 22:51:45.355 INF audio: ( 16 ) Output Device : “Line 6 (Virtual Audio Cable)”
2024-04-29 22:51:45.355 INF default: Looking for inputs
2024-04-29 22:51:45.356 INF audio: "Client Audio input device Microphone (6- USB Audio CODEC ) found! "
2024-04-29 22:51:45.356 INF default: Looking for outputs
2024-04-29 22:51:45.356 INF audio: "Client Audio output device Speakers (6- USB Audio CODEC ) found! "
2024-04-29 22:51:45.357 INF audio: "Server Audio input device Microphone (5- USB Audio CODEC ) found! "
2024-04-29 22:51:45.357 INF audio: "Server Audio output device Speakers (5- USB Audio CODEC ) found! "
2024-04-29 22:51:45.541 INF system: Cannot prepare WF view without rigCaps. Waiting on this.
2024-04-29 22:51:45.545 INF rig: creating instance of rigCommander()
2024-04-29 22:51:45.546 INF cluster: starting dxClusterClient()
2024-04-29 22:51:45.548 INF udp: Starting udpHandler user: “wd4elg” rx latency: 150 tx latency: 150 rx sample rate: 16000 rx codec: 4 tx sample rate: 16000 tx codec: 4
2024-04-29 22:51:45.556 INF udp: UDP Stream bound to local port: 55135 remote port: 50001
2024-04-29 22:51:45.630 INF system: Received CommReady!!
2024-04-29 22:51:45.630 INF default: Setting rig state for wfmain
