I’m currently running WFView as a server on a Linux (ubuntu 24) laptop, USB-connected to an IC-7300. I have WFView running as a rigctld remote on a MacBook, with the usual apps: WSJT-x, FLDigi, RUMLogNG. These play nicely together. But I recently started playing with Nexus – an all-in-one app for several digital modes (FTx, JS8, CW) and adding more all the time. It also includes a logger, rotator control, and tracks awards. It’s rather new, but quite capable. It also plays nicely with the WFView Remote. In addition to an audio spectrum waterfall, it will include an rf scope–if the radio provides the data. Nexus pops up a message that the radio must provide CI-V or SDRPlay data. Is it possible for the WFView Remote to “pass thru” the CI-V data to Nexus? While it seems a bit redundant to have an rf spectrum waterfall on both WFView and Nexus, I’m trying to see everything on a single screen. (A bit of a challenge on a 13" screen!).
You can speak directly with the radio by using the Virtual Serial Port. That is what I would do, for your case. Note that there are two waterfall formats; you may want to try each to see what works.
Hi Elliott,
Thanks for the reply. I wish I understood the VSPs better. I think I have one defined on the remote side as rig-pty1. But I’m not sure how to use it for this purpose. Does CI-V data automagically appear on it, or is there something else I need to configure. Also, Nexus only offers two source selections for the RF Scope source: The Radio, or SDRPlay. Nexus doesn’t seem to know about WFView’s VSPs. If I could speak more intelligently, I’d ask Nexus’ creator to possibly add a hook for WFView (?)
The VSP should operate almost exactly as a serial port. wfview sends and receives CI-V traffic to and from the port.
I do not recall the full path for the pty on macOS, you may need to look at the log file carefully.
Hi Elliott,
Just a quick follow-up. The developer of Nexus made a recent modification to enable it to detect the WFView VSPs. So Nexus can now pull in CI-V data and display the waterfall in its “RF Scope”. The two apps are playing pretty nicely together! (Using the latest GA and the recent Beta3)
Oh hey that is wonderful.
You may also wish to mention to the Nexus developers that wfview v3 supports TCI – which is audio and control data. This is a superior and “next gen” method for radio control with audio
--E
