Will do that.
But this is a case of a client wfview crash when the connection is up but the radio is in off mode. There was two tmp-files on the server side. This is the end of the first, the crash was at 08:19 this morning:
2025-02-06 08:18:06.266 INF udp.server: "::ffff:78.82.103.238" ( "Control" ): Sending Token response for type: 5
2025-02-06 08:19:06.264 INF udp.server: "::ffff:78.82.103.238" : Received token request
2025-02-06 08:19:06.264 INF udp.server: "::ffff:78.82.103.238" ( "Control" ): Sending Token response for type: 5
2025-02-06 08:19:39.518 INF udp.server: "::ffff:78.82.103.238" ( "Audio" ): Deleting stale connection
2025-02-06 08:19:39.519 INF udp.server: Deleting "Audio" connection to: "::ffff:78.82.103.238" : "60634"
2025-02-06 08:19:39.519 INF udp.server: Found "Audio" connection to: "::ffff:78.82.103.238" : "60634"
2025-02-06 08:19:39.520 INF udp.server: Current Number of clients connected: 0
2025-02-06 08:19:39.520 INF audioconverter: Closing audioConverter() Input: 2 Channels of 0 48000 SignedInt 16 Output: 1 Channels of 0 48000 SignedInt 16
2025-02-06 08:19:39.522 INF audioconverter: Closing audioConverter() Input: 1 Channels of 0 48000 SignedInt 16 Output: 2 Channels of 0 48000 SignedInt 16
2025-02-06 08:19:39.523 INF udp.server: "::ffff:78.82.103.238" ( "CIV" ): Deleting stale connection
2025-02-06 08:19:39.523 INF udp.server: Deleting "CIV" connection to: "::ffff:78.82.103.238" : "40771"
2025-02-06 08:19:39.524 INF udp.server: Found "CIV" connection to: "::ffff:78.82.103.238" : "40771"
2025-02-06 08:19:39.525 INF udp.server: Current Number of clients connected: 0
2025-02-06 08:19:39.525 INF udp.server: "::ffff:78.82.103.238" ( "Control" ): Deleting stale connection
2025-02-06 08:19:39.525 INF udp.server: Deleting "Control" connection to: "::ffff:78.82.103.238" : "59266"
2025-02-06 08:19:39.526 INF udp.server: Found "Control" connection to: "::ffff:78.82.103.238" : "59266"
2025-02-06 08:19:39.526 INF udp.server: Current Number of clients connected: 0
This is the second server tmp:
2025-02-06 10:02:05.984 INF system: "wfview version: 1.63 (Git:54b00b9 on Jun 6 2023 at 14:34:21 by pi@raspberrypi). Operating System: Raspbian GNU/Linux 10 (buster) (arm). Build Qt Version 5.11.3. Current Qt Version: 5.11.3"
2025-02-06 10:02:06.113 INF system: Loading settings from "/home/pi/.config/wfview/wfview.conf"
2025-02-06 10:02:06.131 INF rigctld: could not start on port 4532
2025-02-06 10:02:06.132 INF gui: Got Audio Output from Settings: "default"
2025-02-06 10:02:06.132 INF gui: Got Audio Input from Settings: "default"
2025-02-06 10:02:06.162 INF cw: "Sidetone Output: alsa_output.platform-bcm2835_audio.digital-stereo (volume: 0 rate: 44100 size: 16 type: 1)"
2025-02-06 10:02:06.162 INF audio: Audio device(s) found (*=default)
2025-02-06 10:02:07.097 INF audio: * ( 0 ) Input Device : "default"
2025-02-06 10:02:07.098 INF audio: ( 1 ) Input Device : "jack"
2025-02-06 10:02:07.098 INF audio: ( 2 ) Input Device : "pulse"
2025-02-06 10:02:07.098 INF audio: ( 3 ) Input Device : "usbstream:CARD=b1"
2025-02-06 10:02:07.099 INF audio: ( 4 ) Input Device : "sysdefault:CARD=CODEC"
2025-02-06 10:02:07.099 INF audio: ( 5 ) Input Device : "front:CARD=CODEC,DEV=0"
2025-02-06 10:02:07.099 INF audio: ( 6 ) Input Device : "surround21:CARD=CODEC,DEV=0"
2025-02-06 10:02:07.099 INF audio: ( 7 ) Input Device : "surround40:CARD=CODEC,DEV=0"
2025-02-06 10:02:07.099 INF audio: ( 8 ) Input Device : "surround41:CARD=CODEC,DEV=0"
2025-02-06 10:02:07.099 INF audio: ( 9 ) Input Device : "surround50:CARD=CODEC,DEV=0"
2025-02-06 10:02:07.100 INF audio: ( 10 ) Input Device : "surround51:CARD=CODEC,DEV=0"
2025-02-06 10:02:07.100 INF audio: ( 11 ) Input Device : "surround71:CARD=CODEC,DEV=0"
2025-02-06 10:02:07.100 INF audio: ( 12 ) Input Device : "iec958:CARD=CODEC,DEV=0"
2025-02-06 10:02:07.100 INF audio: ( 13 ) Input Device : "dmix:CARD=CODEC,DEV=0"
2025-02-06 10:02:07.100 INF audio: ( 14 ) Input Device : "dsnoop:CARD=CODEC,DEV=0"
2025-02-06 10:02:07.100 INF audio: ( 15 ) Input Device : "hw:CARD=CODEC,DEV=0"
2025-02-06 10:02:07.101 INF audio: ( 16 ) Input Device : "plughw:CARD=CODEC,DEV=0"
2025-02-06 10:02:07.101 INF audio: ( 17 ) Input Device : "usbstream:CARD=CODEC"
2025-02-06 10:02:07.101 INF audio: ( 18 ) Input Device : "usbstream:CARD=Headphones"
2025-02-06 10:02:07.101 INF audio: ( 19 ) Input Device : "alsa_input.usb-Burr-Brown_from_TI_USB_Audio_CODEC-00.analog-stereo"
2025-02-06 10:02:07.101 INF audio: ( 20 ) Input Device : "alsa_output.usb-Burr-Brown_from_TI_USB_Audio_CODEC-00.analog-stereo.monitor"
2025-02-06 10:02:07.102 INF audio: ( 21 ) Input Device : "alsa_output.platform-bcm2835_audio.digital-stereo.monitor"
2025-02-06 10:02:07.102 INF audio: ( 22 ) Input Device : "alsa_output.platform-bcm2835_audio.analog-stereo.monitor"
2025-02-06 10:02:08.413 INF audio: * ( 0 ) Output Device : "default"
2025-02-06 10:02:08.413 INF audio: ( 1 ) Output Device : "jack"
2025-02-06 10:02:08.413 INF audio: ( 2 ) Output Device : "pulse"
2025-02-06 10:02:08.413 INF audio: ( 3 ) Output Device : "sysdefault:CARD=b1"
2025-02-06 10:02:08.413 INF audio: ( 4 ) Output Device : "dmix:CARD=b1,DEV=0"
2025-02-06 10:02:08.414 INF audio: ( 5 ) Output Device : "dsnoop:CARD=b1,DEV=0"
2025-02-06 10:02:08.414 INF audio: ( 6 ) Output Device : "hw:CARD=b1,DEV=0"
2025-02-06 10:02:08.414 INF audio: ( 7 ) Output Device : "plughw:CARD=b1,DEV=0"
2025-02-06 10:02:08.414 INF audio: ( 8 ) Output Device : "usbstream:CARD=b1"
2025-02-06 10:02:08.414 INF audio: ( 9 ) Output Device : "sysdefault:CARD=CODEC"
2025-02-06 10:02:08.414 INF audio: ( 10 ) Output Device : "front:CARD=CODEC,DEV=0"
2025-02-06 10:02:08.415 INF audio: ( 11 ) Output Device : "surround21:CARD=CODEC,DEV=0"
2025-02-06 10:02:08.415 INF audio: ( 12 ) Output Device : "surround40:CARD=CODEC,DEV=0"
2025-02-06 10:02:08.415 INF audio: ( 13 ) Output Device : "surround41:CARD=CODEC,DEV=0"
2025-02-06 10:02:08.415 INF audio: ( 14 ) Output Device : "surround50:CARD=CODEC,DEV=0"
2025-02-06 10:02:08.415 INF audio: ( 15 ) Output Device : "surround51:CARD=CODEC,DEV=0"
2025-02-06 10:02:08.415 INF audio: ( 16 ) Output Device : "surround71:CARD=CODEC,DEV=0"
2025-02-06 10:02:08.416 INF audio: ( 17 ) Output Device : "iec958:CARD=CODEC,DEV=0"
2025-02-06 10:02:08.416 INF audio: ( 18 ) Output Device : "dmix:CARD=CODEC,DEV=0"
2025-02-06 10:02:08.416 INF audio: ( 19 ) Output Device : "dsnoop:CARD=CODEC,DEV=0"
2025-02-06 10:02:08.416 INF audio: ( 20 ) Output Device : "hw:CARD=CODEC,DEV=0"
2025-02-06 10:02:08.416 INF audio: ( 21 ) Output Device : "plughw:CARD=CODEC,DEV=0"
2025-02-06 10:02:08.416 INF audio: ( 22 ) Output Device : "usbstream:CARD=CODEC"
2025-02-06 10:02:08.416 INF audio: ( 23 ) Output Device : "sysdefault:CARD=Headphones"
2025-02-06 10:02:08.417 INF audio: ( 24 ) Output Device : "dmix:CARD=Headphones,DEV=0"
2025-02-06 10:02:08.417 INF audio: ( 25 ) Output Device : "dsnoop:CARD=Headphones,DEV=0"
2025-02-06 10:02:08.417 INF audio: ( 26 ) Output Device : "hw:CARD=Headphones,DEV=0"
2025-02-06 10:02:08.417 INF audio: ( 27 ) Output Device : "plughw:CARD=Headphones,DEV=0"
2025-02-06 10:02:08.417 INF audio: ( 28 ) Output Device : "usbstream:CARD=Headphones"
2025-02-06 10:02:08.418 INF audio: ( 29 ) Output Device : "alsa_output.platform-bcm2835_audio.digital-stereo"
2025-02-06 10:02:08.418 INF audio: ( 30 ) Output Device : "alsa_output.usb-Burr-Brown_from_TI_USB_Audio_CODEC-00.analog-stereo"
2025-02-06 10:02:08.418 INF audio: ( 31 ) Output Device : "alsa_output.platform-bcm2835_audio.analog-stereo"
2025-02-06 10:02:08.418 INF default: Looking for inputs
2025-02-06 10:02:08.421 INF audio: "Client Audio input device default found! "
2025-02-06 10:02:08.421 INF default: Looking for outputs
2025-02-06 10:02:08.424 INF audio: "Client Audio output device default found! "
2025-02-06 10:02:08.430 INF audio: "Server Audio input device alsa_input.usb-Burr-Brown_from_TI_USB_Audio_CODEC-00.analog-stereo found! "
2025-02-06 10:02:08.430 INF audio: "Server Audio output device alsa_output.usb-Burr-Brown_from_TI_USB_Audio_CODEC-00.analog-stereo found! "
2025-02-06 10:02:08.881 INF system: Cannot prepare WF view without rigCaps. Waiting on this.
2025-02-06 10:02:08.898 INF rig: creating instance of rigCommander()
2025-02-06 10:02:08.900 INF serial: Could not open serial port "/dev/IC7300" , please restart.
2025-02-06 10:02:08.900 INF cluster: starting dxClusterClient()
2025-02-06 10:02:08.901 INF udp.server: Starting udp server
2025-02-06 10:02:08.901 INF audio: Audio Input device "alsa_input.usb-Burr-Brown_from_TI_USB_Audio_CODEC-00.analog-stereo"
2025-02-06 10:02:08.901 INF audio: Audio Output device "alsa_output.usb-Burr-Brown_from_TI_USB_Audio_CODEC-00.analog-stereo"
2025-02-06 10:02:08.904 INF udp.server: My IP Address: "0.0.0.0"
2025-02-06 10:02:08.904 INF udp.server: Server Binding Control to: 50001
2025-02-06 10:02:08.905 INF udp.server: Server Binding CIV to: 50002
2025-02-06 10:02:08.905 INF udp.server: Server Binding Audio to: 50003
2025-02-06 10:02:09.323 INF system: Received CommReady!!
2025-02-06 10:02:09.323 INF system: Delay command interval timing: 75 ms
2025-02-06 10:02:09.323 INF default: Setting rig state for wfmain
2025-02-06 10:02:09.324 INF default: Setting rig state
2025-02-06 10:02:09.324 WRN default: QIODevice::write (QSerialPort): device not open
2025-02-06 10:02:09.412 WRN default: QIODevice::write (QSerialPort): device not open
2025-02-06 10:02:09.543 WRN default: QIODevice::write (QSerialPort): device not open
2025-02-06 10:02:09.692 WRN default: QIODevice::write (QSerialPort): device not open
2025-02-06 10:02:09.842 WRN default: QIODevice::write (QSerialPort): device not open
2025-02-06 10:02:09.993 WRN default: QIODevice::write (QSerialPort): device not open
2025-02-06 10:02:10.143 WRN default: QIODevice::write (QSerialPort): device not open
2025-02-06 10:02:10.293 WRN default: QIODevice::write (QSerialPort): device not open
2025-02-06 10:02:10.443 WRN default: QIODevice::write (QSerialPort): device not open
2025-02-06 10:02:10.593 WRN default: QIODevice::write (QSerialPort): device not open
2025-02-06 10:02:10.743 WRN default: QIODevice::write (QSerialPort): device not open
2025-02-06 10:02:10.893 WRN default: QIODevice::write (QSerialPort): device not open
2025-02-06 10:02:11.193 WRN default: QIODevice::write (QSerialPort): device not open
2025-02-06 10:02:11.342 WRN default: QIODevice::write (QSerialPort): device not open
2025-02-06 10:02:11.493 WRN default: QIODevice::write (QSerialPort): device not open
2025-02-06 10:02:11.545 INF serial: Could not open serial port "/dev/IC7300" , please restart.
2025-02-06 10:02:11.545 INF rig: Error using port "/dev/IC7300" message: "Could not open port. Please restart."
2025-02-06 10:02:11.546 INF serial: Closing serial port: "IC7300"
I dont know why there was a second tmp file starting at 10:02, it was probably the time that i connected to the server pi by Windows remote desktop, but I did not do anything to the wfview app at the server at that time.
On the client tmp there was just a stop in the usual sequence of communication when the radio is in off mode, without any special messages. It was not possible to reconnect the client wfview when restarted, without first rebooting the server pi. This is the log after reconnecting:
https://termbin.com/koq9
