Client vs. Server and WSJT-x config
Hi all,
Thanks in advance for the guys that helped me out getting Wfview to work in a client/server model this weekend. My next endeavor is to introduce WSJT-x, my general question for this and similar programs is, will I be configuring only the client, server, or both to get WSJT-x working? I don’t want to break what’s working.
I ask before I do research so I know what to except. the first couple of articles/videos/manual excerpts that I read did not specify.
Thanks.
Hi Frank.
Only the client needs any configuration, this article should help https://wfview.org/wfview-user-manual/hamlib-rigctld-emulation/ You will also need to install audio loopback devices to be able to feed the audio from wfview into wsjt-x which is briefly described here: https://wfview.org/wfview-user-manual/audio-configuration/
Phil,
I started the audio loopback, but want to make sure which machine. Looking forward to giving it a go!
Thanks again!
Frank
